2010 2011 BMW 5 Series Forum F10 BMW N63 engine service action (Service Bulletin B001314) |
01-12-2015, 03:32 PM | #111 | |
Rep 10,185
N63= every oil change (unless replaced in last 12 months) N63tu, S63, N55, N57, N74 = every other oil change (unless replaced in last 12 months) Its SIB 61 30 14 It also says to replace 90AH batteries with 105AH units
BMW if you are reading, I need a job, Please. Last edited by E90Fleet; 01-13-2015 at 08:43 AM.. |
01-12-2015, 06:30 PM | #112 |
Rep 5
Every oil change... So the battery should be under warranty still size it would be less than a year old.
Mine is going in for service next week.. 2 out of the 3 people I spoke with hadn't heard of this "recall" (SIB). So I emailed them everything I find.... Hadn't heard back yet. They did say there are to recalls but couldn't tell me if they pertain to this. Anybody use BMW of Des Moines out there? |
01-13-2015, 02:07 AM | #113 |
Rep 2,246
Some questions:
1. Has anyone been everything short of turned away for bringing your car in for the campaign? After a blood pressure rising back and forth, SA states my car will be returned to me if parts need to be ordered and I'll have to schedule another appointment upon parts arrival. Seems absurd, as I'm experiencing a misfire at this time. Is it even safe to drive a car with a misfire? 2. Is every car that falls under the campaign entitled to an oil and filter change, even if out of warranty? Does it make a difference if the car had a recent oil and filter change (2,000+ miles ago)? 3. Is every car that falls under the campaign entitled to a new battery, even if out of warranty? Does it make a difference whether the car has the 90 amp battery or the 105 amp one? Seems every 90 amp battery should be replaced! 4. Would any of the parts under this campaign remedy a problem where it's difficult to fill one's gas tank because pump nozzles constantly shut off automatically (a problem I've had since my vent lines were replaced due to the smell of gasoline in my cabin)? What a mess. Thanks. Last edited by dbs600; 01-13-2015 at 02:25 AM.. |
01-13-2015, 06:35 AM | #114 |
Rep 5
Seams like this Service Bulletin is only for US, spook to my local dealer today (in Sweden) and they could find anything for my 750i F01.
BMW 530dA Touring Sophisto grey brilliant effect, 20" M Sport 464 v-spoke
See it here |
01-13-2015, 08:44 AM | #115 |
Rep 10,185
Correct, USA only at this stage.
BMW if you are reading, I need a job, Please. |
01-13-2015, 08:53 AM | #116 | |
Rep 10,185
2)The oil and filter change are only if you need your timing chain replaced. This is because they engine has to be removed and opened up to do the job, so the oil and filter needs to be changed regardless of when it was last done. If your timing chain is not replaced there is no oil change required. 3) Batteries are only replaced free on cars still under the USA 4 year maintenance plan. The 90AH ones are being changed to 105 AH on the warranty cars because the 105AH will undergo less stress than the 90AH one. You do not have to replace yours if out of warranty unless you are having low battery issues. A proper Cteck battery charger used every couple weeks will massively help prevent any battery problems by keeping the battery fully charged. 4) No, that is a completely different issue. Sounds like a blocked vent or something.
01-13-2015, 12:01 PM | #117 | |
Rep 2,246
But if the 90 amp batteries are known to be insufficient, shouldn't they be replaced with the 105 amp ones no matter what? When did BMW switch to 105 amp batteries being factory installed? |
01-13-2015, 01:35 PM | #118 | |
Rep 10,185
Lower spec ones got 90AH (some are 92AH depending on make)
01-14-2015, 09:17 AM | #119 | |
Rep 337
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
01-14-2015, 11:09 AM | #120 | |
Rep 2,246
The revised battery replacement policy only protects BMW so customers don't complain of the issue while under warranty, warranties which must be upheld by law. THEN when out of warranty and our batteries die prematurely we are on our own dime, from what I understand. This means there is an obvious design defect and this is wrong. We were not sold cars with the understanding that our batteries would need to be replaced once a year, much less to the tune of $700+. Last edited by dbs600; 01-14-2015 at 04:01 PM.. |
01-14-2015, 02:11 PM | #121 |
Rep 17
i ask here in holland and they said there is no recal on my 550i i gave them my chassie number at the dealer. i even email bmw the netherlands and ask around and they replied back there is no recal so i gave them the b001314 and waiting for response from bmw holland if not im going to try bmw germany or bmw belgium. Or is this recal only in the US.
01-14-2015, 02:30 PM | #122 | |
Rep 10,185
Currently only in the USA.
01-14-2015, 03:31 PM | #123 | |
Rep 510
I get the feeling that so many people in the US are having the same problems that it's affecting the reliability ratings. On top of that, potential lawsuits and forced recall actions by the NHTSA. BMW is probably doing this keep themselves from a PR meltdown. |
01-15-2015, 07:07 AM | #125 | |
Rep 10,185
Often it due to them not having enough parts to issue it everywhere worldwide at the same time. I would expect them to release this worldwide soon. And this way USA customers will be the test cases that will show if the fix works before they send money in other parts where it costs much more to do this.
01-15-2015, 07:45 AM | #126 | |
Rep 712
Drives: 22' M240i
To look back I was literally driving around with fuel spewing out of my car
2022 M240i Thundernight Metallic / Oyster
Previous 2019 540, 2018 M3 CS, 2015 M3, 2011 550i, 2013 335i |
01-15-2015, 10:55 AM | #127 |
"Salud"
13851
Rep 4,677
Drives: F01 & F15 / Mineral White
See my thread here: http://www.7post.com/forums/showthread.php?t=1076902
For my personal results AFTER having received my car back from this Campaign.
01-15-2015, 12:02 PM | #128 |
520
Rep 1,026
Drives: 2018 Shelby GT350
Good morning ladies and gentlemen, for those that are in the SoCal area that have NOT yet taken their vehicles into their local service centers and have questions regarding this recall/s please feel free to PM me about the details that are carried out for such recalls in questions.
-Charlie @ McKenna BMW
Instagram: cboy1
01-15-2015, 03:22 PM | #129 |
Rep 31
Charlie,
My 2011 X5 recently fell out of warranty (11/2014). It has less than 30,000 miles. I had the battery replaced last winter under warranty. I've had the increased battery discharge come on recently. Will BMW provide another battery or do I pay out of pocket? I plan on contacting my local dealership in the next day or so to schedule an appointment. But I would like to know your thoughts first. |
01-15-2015, 05:53 PM | #130 |
Philosophiae Doctor
208
Rep 873
01-15-2015, 06:01 PM | #131 |
"Salud"
13851
Rep 4,677
Yes. Once you have chosen your vehicle and negotiated the best price, this "N63 Discount" is then applied on top of that.
01-15-2015, 06:11 PM | #132 |
Philosophiae Doctor
208
Rep 873
