2010 2011 BMW 5 Series Forum F10 Nitrogen Fill Helps Prevent Flat Tires? |
06-06-2013, 03:07 PM | #1 |
Rep 385
Drives: BMW X3 28i
http://www.nitrofill.com/customerdealers.aspx
A friend of mine uses this instead of "plain air" to fill his run flat tires on his 5 Series. He says that nitrogen doesn't compress the same way air does and this is why it helps prevent flat tires. Anyone else use this product?
2014 BMW 528ix M Sport- Space Gray Metallic, Mocha Nappa Leather, Anthracite Wood Trim. Packages: ACC, DA, DA+, Lighting, Luxury, Prem, H-K SS, SAT, Rear Shade
2013 BMW X3 28i M Sport - Deep Sea Blue Metallic, Sand Beige Nevada Leather, FS Wood Trim, HG Roof Rails, and BMW Apps. Pirelli P7 RFTs. Packages: Cold, Con, DHP, Prem, Premium Sound, Tech |
06-06-2013, 03:22 PM | #2 |
Rep 261
I could be wrong, but I can't see how it would prevent a flat tire. That being said, there in numerous other reasons why nitrogen is better than air in your tires.
Like no humidity (better for your tires) more even tire pressure acros temperatures and probably more. |
06-06-2013, 06:09 PM | #3 |
Long Live the 1911
46
Rep 643
Drives: Hooptie
Helps prevent flat tires? That's ridiculous. The PSI of Nitrogen-filled tires supposedly don't fluctuate with temperature changes as much as oxygen, but I personally found the real-world difference very negligible. Don't ever pay the stealership for Nitrogen when you can get it for free from Costco (even if you didn't buy your tires from them).
06-11-2013, 08:29 AM | #5 |
A family of bimmers
2744
Rep 7,739
dry air contains 78% nitrogen.
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills |
