2010 2011 BMW 5 Series Forum F10 OMG Route 66 Warranty came through for me |
02-13-2020, 03:37 PM | #1 |
Rep 214
Route 66 just paid for nearly $13,000 in repairs at my BMW dealer. I've had nearly no issues with my '13 535i in 69k miles until now.
Got my first-ever Drivetrain Malfunction a couple of weeks ago, the car had reduced power but was drivable (my passengers didn't notice), and didn't come back on after that short trip. 2 days later on my commute to work it came on again - definitely noticed the reduced power, and at highway speeds there was a loud droning sound like you get with wind buffeting when you have one window partly open (but none were). Brought it to the Indy that had been doing routine service since my car was out of factory maintenance period - they couldn't figure it out and said I should bring it to BMW. Next day BMW diagnosed turbo pressure converter failure (somewhat common), and, when they ran the car on a lift, found WTF, rear differential mounts broken and driveshaft coupler broken. Out of balance driveshaft took out the differential and both need to be replaced! Also the common seeping valve-cover gaskets, oil pan gaskets, and oil filter gaskets, which Route 66 covered too. Turbo Pressure Converter: $400 Driveshaft: $2700 Differential/axles: $4800 Valve-cover gaskets, oil pan gaskets, oil filter gasket: $5500 They actually capped the payment at $12,800, the book value of my car at the time, but holy shit! My SA had never heard of Route 66 before (he was wary when I brought the car in and told him I have a 3rd party warranty), but has said they were the best warranty company he's dealt with besides BMW. After the diagnosis, Route 66 sent someone to the shop to inspect it before authorizing, and then again after the work was done. So it took about two weeks in all. Bullets, dodged.
2013 535i M-Sport: Carbon Black with Oyster/Black Dakota, SAT, Driver Assistance Pkg, Premium Pkg, Multi-Contour Heated Seats, Navigation, H/K stereo. Michelin Pilot Sport 4S non-runflats, M5 grille, Painted reflectors from IND.
02-14-2020, 07:34 AM | #4 |
Rep 1,261
Never heard of a broken rear diff mount failure on here. The turbo pressure converter was common and BMW actually extended the warranty for it.
As for the warranty, you paid for it to keep you safe from really high and unexpected repairs like this...And it did its job. |
02-14-2020, 09:48 AM | #5 |
Rep 452
yeah rear diff mounts do wear and sometimes break. theres a diy on youtube for them. 69k is really low miles for those type of issues imo. just fyi the turbo pressure converter/solenoid is ~$100 part, just replaced myself (about 30 min) so $400 is pretty steep, the drive shaft and diff can be pricey. and those numbers a scary. but hey if warranty is picking it up...
still amazed that they covered that amount. might have to look into them. either way glad it worked out for you Last edited by Trainwreck914; 02-14-2020 at 09:59 AM.. |
02-14-2020, 10:57 AM | #6 |
Rep 210
It's nice to have that stuff covered under warranty but that's part of the reason the warranties are so expensive for BMW's. A good, used driveshaft and differential might cost you $300-500 and the other gaskets are probably $300-800 (depending on if you also replace the valve cover). A decent DIY home mechanic could get this fixed for under $1000.
This is also why medical insurance in the USA is so expensive vs other countries. |
02-16-2020, 01:15 PM | #7 | |
Rep 274
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
02-16-2020, 09:57 PM | #9 | |
Rep 214
Rear axle: $3415 Drive Shaft: $1780 Turbo pressure converter: $191 Everything else was gaskets, bolts, fluids, etc nothing over $100. So I paid about $1000, about $500 was tax and the rest due to the blue book cap. Still, while I'd expect no pushback on the obvious failures of the pressure converter and drivetrain, I was pleasantly surprised that the expensive oil leaks were covered, since those seems to be a common issue to expect to pay out-of-pocket as these cars age. Again, my BMW SA said they were great to work with, though diligent in sending someone to see the car before the work and again after.
03-05-2020, 07:23 PM | #10 |
Rep 214
A little more good-news followup, they paid me about another $1000. I mentioned that my repair had been capped at $12,800 (per the policy, the "NADA Actual Cash Value" at the time). After I got my car back, I checked the NADA site, and it showed about that for Average Trade of a base car. Adding the options (the only ones of value were M-Sport and Driver Assistance Pkg), showed Average Trade of $15,275 and Clean Trade of $16,725.
I called them to ask where they got the $12k figure from, explained what I saw on NADA, they sent it up to underwriting, and came back with revised value of $16,750, and cut me a check for about another $1000. So I've still got some headroom in case anything else comes up.
mediocrechris40.00 |
03-06-2020, 07:55 AM | #11 | ||
Rep 1,261
03-06-2020, 03:23 PM | #12 |
Rep 684
cna offera a warranty that covers literally almost everything much more than bmw certified warranty. They replaced my idrive knob in one 5 min phone call they approved an 800 dollar part. I bought it through bmw for close to 5k. I got protection for 6yr or until i hit 160k miles.. i still got cpo to they run active at the same time... I think cna is better than route66 for sure, all i got is a 100 deductible no caps, no limits, and the whats not covered section is very short and sweet pretty much only stuff listed there is items like tires, wheels (I got cna Wheel&Tire that covers both) body panels, brake disc/pads, and stuff that is wear and tear which really shouldnt be covered in the first place.
03-06-2020, 08:34 PM | #13 | |
Rep 5,365
03-06-2020, 08:39 PM | #14 | |
Rep 109
ezaircon4jc4483.50 |
03-07-2020, 11:17 AM | #15 | ||||
Rep 684
The specific one i got i think is only offered at the dealer when you buy the car and i got a specific one that requires the car to be bmw certified as well on top of that but it covers soo much its crazy and the dealer sells it so they communicated and approve repairs with them on call quickly.. |
03-07-2020, 04:04 PM | #16 | |
Rep 274
03-08-2020, 10:26 PM | #17 | |
Rep 150
Thank you for considering CNA National. Our products are sold exclusively by automobile dealerships at time of vehicle purchase and not all vehicles qualify. We appreciate your interest, but we do not sell directly to the public. My 3 yr 3rd party warranty is ending in august and I need to find another one that will sell to me directly. I'm fine going to a shop to get the car certified in some way if that's a prerequisite. Does Route 66 offer warranty contracts direct to consumer? |
03-09-2020, 04:21 PM | #18 |
Rep 214
You have to buy it through a Credit Union, but it's real easy. Contact Route66 from their website, they'll email you credit union(s) near you that sell them. Contacted the credit union for the quote (they give different time/mileage levels), and I only had to open an account with $1 in order to buy the warranty. All done electronically/phone, didn't need to go to an office.
