2010 2011 BMW 5 Series Forum F10 Shifter stuck in Park, solenoid? |
01-05-2019, 08:29 AM | #1 |
Rep 88
Guys, my shifter is stuck in park again....
I'm able to get it unlocked by rocking shifter from drive to reverse.... My car 535 x drive 2013 m sport package with 115000km or 71000miles. I'm hoping it's not a transmission problem but a faulty solenoid or kinked wires..... It's happened 3 times in the last 12 months. The first time is was super cold -25c or -14f. The 2nd and 3rd time the temperature was about -2c or 28f. Not sure if the cold weather may stimulate this issue? The car and transmission runs perfectly. When it happened the first time the BMW mechanic verified everything and was not able to reproduce issue. What would my next steps be? I'm scheduling a transmission fluid + pan + filter job soon, not sure this will help. Thanks Sergio |
01-10-2019, 06:56 AM | #2 | |
Rep 88
I love my 535, really hope it's a minor issue. Thanks for any feedback or comments on this Sergio |
04-06-2020, 09:06 PM | #3 |
Rep 86
Hey there, did you ever figure this out? Looking at a 2011 535 x drive and he says this happens time to time randomly
04-07-2020, 09:23 AM | #4 |
Rep 1,564
Most likely is the park solenoid, it's pretty easy to replace as it sits apart from the main group of shift solenoids on a separate wire harness. You should be able to replace it without removing the valve body. I just replaced all of my solenoids so I did it with the valve body removed (have to for shift solenoids) but the green park solenoid looked easy to replace while the valve body is still in the transmission so anyone who can change the oil should be able to do it.
04-07-2020, 02:56 PM | #5 | |
Rep 452
04-07-2020, 06:27 PM | #6 |
Tasmanian
28
Rep 102
Hello
I had a similar problem. My fluid was a little low and the transmission needed to be reset. It seems that unless everything is OK, it will not release the electronic parking brake. The solonoid does not fully engage the brake to release it, so it sends a signal and will not allow you to select a gear. By changing the fluid and resetting the transmission level so it learns how much fluid it has, this problem went away. A local transmission shop diagnosed and fixed the problem Thanks Tasmanian |
04-07-2020, 06:58 PM | #7 | |
Rep 1,564
https://www.ebay.com/itm/ZF-Genuine-...oAAOSwsFheQcM4 Get the shop manual too, everything you need to know, makes working on it easy: https://www.amazon.com/ATSG-ZF8HP45-.../dp/B079X43XG9 And finally I recommend replacing the small b clutch mechatronics sleeve if your doing all the solenoids and pulling the valve body. Here is a link to it (has the other sleeves you need to replace too if pulling the valve body). I have 150k miles on mine and after changing out the solenoids and mechatronic sleeves, it's shifting back like it should (was horrible before and almost undrivable, filter/ change, valvebody rebuild, adaptations reset didn't help at all until the solenoids/sleaves were replaced) https://www.ebay.com/itm/OEM-ZF-8HP4...-/184093768185 Last edited by Sophisticated Redneck; 04-07-2020 at 07:10 PM.. |
04-08-2020, 08:33 AM | #8 |
Rep 452
I know on the e90 the sealing sleeves tend to get brittle and seep causing loss of pressure. As well as the gear selector shaft breaking (metal married to plastic). I did that job. But did not change the sleeve at that time. But haven't seen these parts being offered for the f10 until now. I figured a place like fcp euro would offer this. But they only have the external sleeve.
https://www.fcpeuro.com/products/bmw...zf-24147588896 Adaptation reset. Where you hold down the accelerator, helps my situation. My up shifts are smooth. It's my downshifts only low gears that isn't. And occasional. I have 125k now. Changed fluid and pan/filter just before winter. Helped a bit. About 4 qt came out and went back in. Used zf fluid and pan. Expensive stuff @ $30 qt https://www.fcpeuro.com/products/bmw...-24118612901kt |
04-08-2020, 08:53 AM | #9 | |
Rep 1,564
After changing out the solenoids and sleeve (the zf8 really only has 2 that can affect shifting and in mine only the b-clutch sleeve was bad) it is like driving a completely different car and is fun to drive again and 150k miles life for solenoids is acceptable to me. Fcp will probably eventually carry it like they do for the 6hp. Problem is the shortage. I tried every shop in town and even rebuild shops across the country trying to get the solenoids with no luck and had to turn to eBay. |
04-08-2020, 09:00 AM | #10 |
Rep 452
Wow. Yeah My experience isn't anywhere near as bad as that sounds. But it's not a smooth as I know it should be. My wife has a f15 X5 and her zf8 is as smooth as butter. What is the B clutch sleeve? Is that sold separately? Could you have gotten away with only doing that solenoid and the seals?
04-08-2020, 11:31 AM | #11 | |
Rep 1,564
04-08-2020, 01:38 PM | #12 |
Rep 452
I planned on doing another oil change soon. So I'll plan ahead. Before I tear into it again. It was tedious and time consuming the first time around. Plus I have x drive. So the mechatronic sleeve in a bear to get out with the transfer case having to be removed.
04-09-2020, 12:29 PM | #13 | |
Rep 1,564
Make sure to get about 7 Liters of oil vs the normal 5 for a standard oil change too as two more liters come out when you pull the valve body. |
