02-27-2020, 08:59 AM | #1 |
Petrolhead
440
Rep 808
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
20" Tire Sizes
Ok, my state inspection is coming up so I'm at that point now where I need to decide whether to stick with my 19" OEM rims and get a new set of the horrid run-flats, or to jump ship and get 20" wheels since I have to get all new tires anyway.
I'm trying to see my options for 20" tires but there is literally one all-season tire available on Tire Rack for the recommended size. Are there other 20" tire sizes/staggered combos that have been tested to work without any rubbing or other issues? This is what Tire Rack (and I assume BMW) recommends: Front 245/35-20 Rear 285/30-20 |
02-27-2020, 09:45 AM | #2 |
Rep 7,484
Why are you "assuming" what the BMW recommendation is? You can look this info up in your owners manual. It will be listed with the recommended tire pressure info in the owners manual. Using the BMW recommended tire sizes...you may find more than one all season tire offering.
And you may also find other tire offerings if you check some of the other national tire chain stores. Sometimes they offer other brands that the others don't. In that regard I would recommend checking:
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 02-27-2020 at 10:06 AM.. |
02-29-2020, 04:15 PM | #4 |
Rep 53
I HaVE driven around DC quite a bit and am not sure why you would want 20’s. Just looks? Certainly not for performance, right? I would stick with the 19’s. Even those are a bit too big for a large 4 door sedan.
2016 528iXDrive
1988 Carrera Coupe |
03-01-2020, 05:38 PM | #5 |
Rep 20
I live in dc and I’m running 255f and 295r. Performance wise they are much better suited than the 18 inch 245 square. I have more grip, the back end doesn’t slide as quickly or at all and I’m equipped with xdrive. In addition to that speed bumps are easier to go over compared to the 18 setup. Sure the ride is rough at some points but I ran runflats when I got the car and it still doesn’t feel as rough as those.
03-01-2020, 09:54 PM | #6 |
Rep 87
With the F10 chassis 18" wheels are about perfect but you can go for 19's if they are a lightweight wheel... BMW's OEM wheels are quite heavy.
I don't see why on earth you would need to go for Run-flats again. Just buy regular tires for your current set of wheels, or buy some nice aftermarket 19's instead. |
03-02-2020, 07:45 AM | #7 |
Petrolhead
440
Rep 808
That's def. always in the back of my mind. I've amazed by the amount of abuse the stock BMW 19s take on DMV roads and yet no cracks or bends.
I don't really have a strong desire to get 20", just an opportunity since I have to get all new tires. With that said, I might just stay my 19s and get them powder coated in gunmetal. Definitely gonna drop the run-flats completely.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) Last edited by spielnicht; 03-02-2020 at 09:13 AM.. |
03-02-2020, 11:32 AM | #8 | |
Rep 965
03-02-2020, 11:57 AM | #9 |
Rep 20
20x9 32 and 20x10 35 for rear. No need for spacers because the wheels are out to the fenders and not beyond. It looks crazy when looking at the rear though, aggressive as hell. I have the Beyern Gerade wheels in matte black.
03-02-2020, 12:16 PM | #10 |
Rep 965
M5 wheels are 20x10.5 +34 in the rear lol. maybe I should stick with 285..
03-08-2020, 04:54 AM | #11 |
Rep 1
If you are trying to find the best and perfect flushing toilet for your bathrooms, you should never forget the Kohler Cimarron https://bestflushingtoilets.org/kohl...marron-review/. Kohler has been well known for producing great flushing toilets and having various outstanding features that make it fun to install in your bathroom. Don't miss this out!
03-09-2020, 02:55 PM | #12 | |
Rep 274
The M6 343M wheels are wider with different offsets: F: 20x9.5 +31 and R: 20x10.5 +19. I'm also trying to run the stock M5 tire set up on the 343Ms: 265/35R20 and 295/30R20. I have M Sport 704 suspension which is 10 mm lower than standard. Any thoughts on if this would work? I think the fronts should be fine but rear might rub under load.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i |
03-09-2020, 04:14 PM | #13 | |
Rep 965
03-09-2020, 11:45 PM | #14 |
Rep 14,522
sorry but this made me chuckle.
