2010 2011 BMW 5 Series Forum F10 does this happen to your f10? |
06-27-2011, 12:53 PM | #1 |
twin-turbo baby!
17
Rep 150
When starting my car in the morning everything runs fine. When i goto lunch around 12-1 car is parked outside in the sun...when i start my car the rpm starts going up & down for like 5 seconds really fast. does anyone know the problem for this?
2011 535i Alpine White
Premium Package, Sport Package, Navigation System, PDC, & Rear-View Cam |
06-27-2011, 01:22 PM | #2 |
Rep 6,697
Yes, my car does this. My dealer says it's normal due to "hot air in the intake tract, between the MAF and the throttle".
I call Bullfeathers on this one. I ran a Volvo V70R with a tune that was running much more boost than this car, and it never did any of that crap, even stock. Bringing it back in for other issues, will have them look at this again. |
06-27-2011, 01:57 PM | #3 |
Rep 519
My RPM does not go up but more often than not, my cooling fan goes to a very high speed for a few seconds and sounds really loud. After 5 to 10 seconds it then goes back down to where I can't really hear it.
06-27-2011, 07:32 PM | #5 | |
twin-turbo baby!
17
Rep 150
Actually you explained it better then i did...hahaha but, yeah i do hear the fan going really high speeds for 5-10 seconds but my rpm goes up & down while its doing that. Then when it stops the Rpm is back to normal.
06-27-2011, 09:18 PM | #7 |
Rep 582
Yes, I have this same rpm issue but not with every start. It is very annoying and I had dealer check it out last week. They said they noticed it however car is operating as designed. I think that is BS! I never noticed this problem until after they performed softward update for steering issue.
06-27-2011, 10:20 PM | #8 |
Rep 1,684
This is most likely completely normal. You are still dealing with a mechanical device. The engine management system is permitted to tweak the engine during idle as a means to stabilize the engine or otherwise manage excessive emissions.
Now, if you throw it into gear during this time and the engine stutters or acts strange then you may have a valid complaint. But, idle management routines that fluctuate engine rpm are typically under control of the computer. You will see similar throttle activity during idle when the engine is cold and when the engine executes some break in logic. Again, next time this occurs throw it immediately into gear and you will see that vehicle drive performance remains virtually unaffected. [QUOTE=Evil335i;9905373]When starting my car in the morning everything runs fine. When i goto lunch around 12-1 car is parked outside in the sun...when i start my car the rpm starts going up |
06-28-2011, 01:49 AM | #9 |
Rep 1,134
Same as mine, when its hot I notice fan starts up on initial turn over at high rpm for a few minutes and then goes to normal. I have also had it stay on high rpm AFTER I shut the car off in the garage. My home is just a short distance from the entrance/exit ramps to unrestricted part of the autobahn so more often then not my car was running well over 100mph shortly before pulling into the garage.
2014 550i M-sport
06-28-2011, 09:17 AM | #11 | |
Rep 68
06-28-2011, 02:16 PM | #12 |
twin-turbo baby!
17
Rep 150
This actaully happen to me after i passed 5k miles. But during that time it wasnt hot here in so cal. Just recently got hot here.
09-13-2011, 12:20 PM | #13 |
Rep 99
Is there any solution to the rough idle after a warm start? my 535i x is doing it for about 5 to 8 seconds after a warm start (engine already warm), it does not happen on a cold engine start....
09-13-2011, 01:39 PM | #14 |
Rep 282
Yes, mine does this too. My dealer said it was normal. I say it's a bull.
09-14-2011, 11:27 AM | #16 |
Rep 552
I noticed it on my test drive before buying the car and the sales manager said it was normal. Still does it today. My 335i did it as well.
2019 RANGE ROVER SPORT SUPERCHARGED; 2023 JEEP WRANGLER RUBICON 4XE
2022 AUDI R8 PERFORMANCE RWD; 2023 BMW M3 XDRIVE; 2017 MERCEDES G550; 2023 CORVETTE Z06 (ORDERED) |
09-15-2011, 04:56 PM | #17 |
Rep 53
Drives: '24 BMW i5 eDrive40
Dealer duplicated problem with idle rev-up
said they checked with BMW and were told that the bug was in the latest software installed to correct the pull to the right problem. "BMW is working on a fix"
02-25-2012, 02:37 PM | #20 |
Rep 53
My 2011 535i did this idle thing and the dealer could not fix it after many attempts. I now have a new 2012 535i courtesy of BMWNA and my dealer.
I cannot say enough about the great support that BMW of Palm Beach gave me. Problem solved. |
02-26-2012, 01:55 PM | #21 | |
Rep 242
I live in Sweden, no problems with the sun here either... :lol |
02-26-2012, 02:17 PM | #22 |
Rep 6,697
Wow. Wish I could get the same for my problem. I can replicate it at will..simply let the car come up to temperature, shut it off and then start at least an hour later. Bingo revs flare like no one's business.
