2010 2011 BMW 5 Series Forum F10 Any solution for car holding gear |
01-30-2023, 10:09 PM | #1 |
Rep 77
Drives: 2015 535i xdrive, 2014 x5 35i
I believe the following description is normal transmission behavior, but i'm looking to see if any alternative exists.
In Sport mode or DS, when i accelerate strongly to highway speeds, but then release the accelerator, i would prefer if the trans would shift right away to a higher gear, but instead the RPM's hold at the high level for way too long, before deciding to shift. I would like to use Sport and DS a lot more, but the trans holding the high rpms bothers me too much, and i end up after one acceleration, just moving to comfort or normal shift so that the trans will shift and RPMs lower. Is there any way around this? Is there any way to get that trans to shift automatically instead of holding the gear. If not a setting possible within the car, with any 3rd party product? |
01-31-2023, 06:05 AM | #2 | |||
Rep 15,858
We've had this feature since the introduction of the ZF 5-speed. Driving style can reduce the shift hold from causing any issue. Quote:
02-03-2023, 07:06 PM | #3 |
Rep 333
Drives: F10 535i xDrive, F25 xDrive35i
Right on the money. Need to understand how it works!
In sport (shift lever to the left), if you slowly release the accelerator pedal, it shifts up quickly (I.e doesn’t hold revs). But quickly releasing it makes it hold the gear much like in a manual transmission. |
