2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Big bill after 27 months of worry free driving
      01-30-2018, 05:56 PM   #1
SilverSlurf
Drives: 2012 535i sport
So quick background, I bought a used 2012 535i in 2015 with 32k and she now has 76k. Literally no issues until last week. I was driving and got the dreaded engine temp high and yellow limp. I promptly stopped, topped off coolant and no issues. Fast forward to Sunday, I start hearing squeak noises from the engine bay. Turns out my oil filter housing was leaking into my belt...I should have noticed lol. Anyway, take her in to my Indy, waterpump/thermostat, both oil filter housing gaskets and pulley, tensioner and belt replacement. Bill is 880 + 400 + 380 respectively. She's been good to me and although it's a 1700$ bill I don't mind it. With that said...keep an aye on your oil filter housing and do the diy while you can.
I figure I'll tackle the cooling system and spark plugs/coils in the next 10k.
      01-30-2018, 06:36 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
just had both oil filter housing gaskets replaced because BMW said it's leaking onto the belt. cost me just under $500 for an Indy shop to do. BMW wanted $900
      01-30-2018, 07:02 PM   #3
Stück
Stück's Avatar
Pretty typical maintenance for 76k, OFHG has likely been leaking to some degree since 55-60k.
Why didn't you come see me?
      01-30-2018, 07:44 PM   #4
Do you make house calls?
      01-30-2018, 08:36 PM   #5
SilverSlurf
I did an oil change at 70k. I used 0w instead of 5w I had no leaks before then. should I go back to 5w?
Tbh I didn't even think to look on the forum. But I need my coils and sparks done soon, I'll definitely come see you. PM me your info @stuck
      01-31-2018, 11:08 AM   #6
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I'm running 0w. And by me, I mean the BMW dealer where is got serviced.
This is why it pays to have an extended warranty.
      01-31-2018, 11:28 AM   #7
Trian
Drives: 2015 535i M-Sport
I agree. I have a 2012 535i currently at 99,010 miles. I just did the water pump/thermostat 1,000 miles ago (went out stranding me on the way to Disney with company), the tensioner belts and pulleys 8,000 miles ago (because they were making noise and my Indy said do it before, not after), front blower motor 10,000 miles ago, as well as the oil gaskets at the same time. Before that, just basically tires and oil changes.
Everything I have read says these items (except for fan) are pretty standard for the 2012 535i
      02-19-2018, 10:18 PM   #8
louieeg
Drives: 2015 BMW M4 coupe
Is there a DIY for the oil filter housing? I have a pool of oil on the top of the housing.
      02-19-2018, 11:00 PM   #9
There's a YouTube on the repair...
      02-28-2018, 06:58 PM   #10
louieeg
I ended up paying an indy shop $490 for the repair. Didn't want to risk dropping a screw in that mess.
I guess the gasket has been a problem for multiple generations, and still not fixed by BMW. Same with the VC gaskets, which my car needs. Unacceptable. I think BMW will start to feel the pain of losing customers....I don't see how they can survive longterm with this kind of track record.
      02-28-2018, 11:52 PM   #11
Valve cover gaskets fail on ALL cars over time...
      03-01-2018, 12:31 AM   #12
lsturbointeg
Haven't had mine replaced yet. You think my Indy shop would have noticed when they changed my oil filter gasket housing?
      03-01-2018, 12:48 AM   #13
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Yes... my old e60 was leaking and it was a pain cuz 2 of the bolts broke off... luckily I was able to get it out..
      02-12-2019, 10:56 PM   #14
SilverSlurf
i had 76k a year ago when i made this post and now im at 97k....where the hell am i driving lol
      02-20-2019, 04:59 PM   #15
agentorange
Drives: 328d
Oil filter housing gasket seems to be a popular failure on many vehicles. Had it done before Christmas on the Nissan truck I drive.
      02-20-2019, 07:14 PM   #16
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
72k miles and I have not had valve cover, or OFHG replaced and it wasn't leaking when I had the oil changed 3k miles ago. This is another reason I like to do 5k oil changes instead of 17k (or whatever BMW recommends on 2011 535i).
      02-21-2019, 08:22 AM   #17
starlights
Drives: G05 50i
Please elaborate. How does more frequent change affect or preserve the gaskets? Is it the quality breakdown of oil over a longer time that leads to the leaks in some way?
Thanks!
      02-21-2019, 03:08 PM   #18
harris69
Thanks!
It is not the frequent oil changes that saves the gaskets, but rather frequent trips (instead of once in 17k miles) where problems could be caught early rather than finding out that a leaky ofhg caused the belt to slip and caused $4k worth of damage.
Every 5k miles I am at my Indy, and while the car is on the lift I ask my mechanic to look for anything that might be of a concern.
      02-21-2019, 03:20 PM   #19
starlights
Drives: G05 50i
Ah - okay that makes sense. Thanks for responding.
      02-22-2019, 08:33 AM   #20
harris69
No problem. If you are mechanically inclined you could check for potential problems yourself, but I am not; so I rely on my mechanic...I guess things can still happen in between oil changes but I rather take a gamble on 5k than 17k miles.
