2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 9.5j/10j et35 both. Fit on F10?
      08-17-2020, 07:00 AM   #1
atabi
Drives: 530D F10
Hey guys.
Want to change my 464m wheels for forged ones.
I have ProDrive Japan forged wheels, front 9.5jx19 et35 / rear 10jx19 et 35.
Will they fit on my 530dx f10?
What tire width is recommended for such wide wheel?
Thanks!
      08-17-2020, 12:46 PM   #2
CanadianTSi
CanadianTSi's Avatar
Drives: 2014 535 xDrive Diesel
9.5 35 offset won't clear in the front without a spacer. I would guess 5mm at minimum.
      08-18-2020, 06:06 AM   #3
spielnicht
Petrolhead
spielnicht's Avatar
440
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Depending on which front caliper you have, you can tell whether you would need the 5mm spacer or not.
If you follow the link below, you'll be able to visually tell which caliper you have. If you have the smaller one (2nd pic), then you'll definitely need the spacer. Visually verify your front calipers - don't just got by some of the comments of what year and model have which caliper. The comments made it sound like I have the problem caliper (2nd pic), where in reality I don't - so didn't need a spacer with my new wheels.
Some opt for the 10mm spacer so it's hub-centric and eliminates the vibration normally associated with spacers.
https://f10.5post.com/forums/showthr...=693143&page=6 (POST #121)
2024 X3 M40i
2014 550i
2008 Z4 3.0si 6MT
2011 Z4 35si (sold)
Tags
f10, wheels
