2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Other BMW wheels fitment to F10
      01-02-2016, 09:39 AM   #1
gtthree
Drives: F10 530d
I'm looking to move off runflats to conventional tyres and I’m seeking to put together a spare wheel to keep at my home should I be unfortunate to suffer a puncture.
With the idea that I get the car recovered to home, swap out the wheel and then get the puncture repaired or the tyre replaced at my choice of supplier. I have 19inch 351’s so it makes sense to shop around for the tyres.
Can anyone advise what other BMW wheels will fit even if the offset is not the same.
I know I will need a 17inch wheel.
Thanks
      01-02-2016, 11:23 AM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
F10 offset on the 8x17" and 8x18" wheels are ET30, I'd be careful getting wheels with a higher offset as you might not clear the brakes/calipers. You got a 530d right?
      01-02-2016, 02:15 PM   #3
gtthree
Drives: F10 530d
Hi Remmib
Its a 530d yes so it has the larger 348 x 30 brakes at the front.
I currently have the 351 wheels which are 19 inch staggered
Front 245/40/19
Rear 275/35/19
Which from I gather from the internet are
19"x8.5 ET33 for Front
and
19"x9 ET44 for Rear
The other requirements will be
centre bore 72.5mm
bolt 14 x 1.25
pcd 5x120
Ideally I'd like a 17inch wheel so that I can put a spare tyre on it cheaply.
Thanks
      01-03-2016, 05:10 AM   #4
remmib
remmib's Avatar
Norway
1568
The safest will be to look for a used 17" wheel from a F10/11 so you know it will fit.
      01-05-2016, 09:46 AM   #5
gtthree
Drives: F10 530d
Thanks, from my research I agree.
