2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Battery discharge while stationary warning?
      09-02-2011, 03:53 AM   #1
Breach
Drives: F10 520dA M Sport
Hi,
I went on a 1 mo. holiday and the car stayed in the garage. When I came back and turned on the ignition I received the following message:
"Increased battery discharge while stationary, some electrical consumers may have been switched off"
I had no problems starting the car and it seems to have been a warning which since the restart went away, but still - is this normal?
Thanks
      09-02-2011, 03:58 AM   #2
inny
Cyprus
Drives: F10
2011 BMW F10  [0.00]
1995 BMW E34  [0.00]
2007 BMW E60  [0.00]
I will go with the assumption that is normal after 1 month in the garage. I would also check to find out on which battery voltage the car throws that message.
But yeah one month is long I think and might be normal. Does it give you the massage now as well?
      09-02-2011, 04:03 AM   #3
Breach
Thanks - no, it went away on the next engine start and I haven't seen it since.
      09-02-2011, 04:15 AM   #4
inny
Cyprus
Drives: F10
2011 BMW F10  [0.00]
1995 BMW E34  [0.00]
2007 BMW E60  [0.00]
Probably its because of "sitting" that long. Because either way even if idle, the car systems work on minimum consumption as every other electric/electrical appliance.
On my e60 i was having that message repeatedly even after i changed the battery twice in a month but then we found out that it was because of a faulty engine starter which was drawing lots of power and draining the battery, till one day the car would not start up. Replaced the starter and now its all good.
      09-02-2011, 09:16 PM   #5
tdepetra
Drives: 2011 535xi
While we were traveling for three weeks earlier this summer, my car was connected to BMW's Battery Tender, yet when I went to start the car for the first time, it gave me the same message. That tells me the message is activated by the length of time the car has not been driven rather than actual battery condition. The car was fine and the message disappeared after I restarted it. Sound like Windows?
