2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 535xi offset question
      06-05-2016, 09:56 PM   #1
Crimedog04
Drives: 2011 335xi 6MT
Looking at a set of avant garde m621 for a friend who has a 535xi. Will they fit properly?
Specs are:
19x8.5 +35 225/35
19x9.5 +45 255/30
Thanks
      06-06-2016, 12:23 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
The offsets will work but are conservative for F10, better suited for F30 (3 Series).
The tires are 2" too short and can not be used on F10. Those sizes are for E90 (the previous generation 3 Series).
      06-06-2016, 09:40 AM   #3
Crimedog04
When you say are too short and can not be used....can you explain that further? Because that tire setup is the closest you can get to equal rotational diameter, besides square, on 19" wheels.
Regarding to the offsets...I'm not looking for something aggressive, but I also don't want it to look too sunk in the fender as well.
      06-06-2016, 10:05 AM   #4
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Those tires are 2" shorter in diameter than OEM sizes for F10!
You may use them but I wouldn't do it. There are quite a few cons with 225/35-19 front and 255/30-19 rear on F10:
- 6% shorter than OEM size
- Speedo will be off
- Odometer will read more miles than you drive
- Increased wheel gap
- Reduced ground clearance
      06-06-2016, 10:07 AM   #5
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
A better staggered 19" tire setup for F10 xDrive would be:
F: 245/40-19
R: 285/35-19
      06-06-2016, 10:20 AM   #6
Crimedog04
Thank you, I appreciate the info.
