2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Head Light Bulb Spec Question
      07-17-2011, 08:43 PM   #23
blackberrycubed
Drives: 535i Xdrive
So the stock F10 bulb is Osram 4300k ?
Thanks !
      07-20-2011, 01:00 PM   #24
blackberrycubed
Drives: 535i Xdrive
^can anyone confirm?
      07-20-2011, 01:13 PM   #25
bobblehead
bobblehead's Avatar
Drives: warp speed
Well, based on Osram's own spec - product ref 66144. It's 4150K, max 3200 lumens
      07-20-2011, 01:32 PM   #26
blackberrycubed
Drives: 535i Xdrive
Thanks. I ordered a set of the CBI 5000k bulbs. Headlights are gonna look badass!
      07-20-2011, 01:38 PM   #27
bobblehead
bobblehead's Avatar
Drives: warp speed
U ordered from Matt (retrofit source) ? If so, hope U got a good deal. If not, who did you order from (if you don't mind me asking) ?
      07-20-2011, 02:41 PM   #28
blackberrycubed
Drives: 535i Xdrive
Yes, I got them from Matt @ retrofitstore. $175 shipped.
He has got one last pair left.
      07-20-2011, 04:21 PM   #29
bobblehead
bobblehead's Avatar
Drives: warp speed
Like your feedback when installed. I have heard it will take about a bit of time (probably about 50+hrs or so) to burn in ... to get the fullest white.
      07-23-2011, 12:14 AM   #30
blackberrycubed
Drives: 535i Xdrive
Installed the puppies today... Love'em !!!! Day/Night difference in the output and color.
Question: Is it possible to screw up the height adjustment during the removal and install process? I pretty sure its the brighter bulb ... as i feel the cutoff is higher?
      07-23-2011, 06:48 AM   #31
bobblehead
bobblehead's Avatar
Drives: warp speed
I think it's only your eye perception as your eyes see whiter color more crispy.
You checked the bulb stamped on the bottom says Osram with the mark of Made in Germany
Technically, CBI - since it's 5000k vs stock 4150K, the higher the temp, the lower the lumens .... that's why all car manufacturers select 4100 - 4300k as their stock bulb as it gives out the maximum lumination.
The Osram CBI bulb needs to boost the lumens back up to the stock 3200 lumens with their newer technology. Therefore, you now have the best of both worlds, much whiter color and maximum lumens .
Although it's a bit pricey, I thinik $ well spent.
      07-23-2011, 12:19 PM   #32
blackberrycubed
Drives: 535i Xdrive
^ I agree, I think it is my eyes and once they adjust in a few days it should be all good.
Just an FYI:
* The stock bulb that came out is Osram 66140 (Made In Germany) and has a brown return wire
* The CBI bulb from Matt@theretrofitsource is Osram 66140CBI (Made in Germany) with a blue return wire.
* I did not jack up the car, but turned the wheel one way to pull the screws out and then the other way to actually replace the bulb.
* Once you pull out the stock bulb, there is a black round locking plastic piece that needs to be carefully removed and moved over to the new bulb before placing it back in the headlight. You want to make sure you do not touch the glass of the bulb during this step.
* Rotating the bulb counter clock wise for removal *can* require some force but do so very carefully not to knock things out of alignment.
It took me about 30 minutes to do the whole procedure. Space is tight and people with big hands are gonna have a tough time getting the power cable attached back to the bulb.
Lastly, these CBI bulbs are worth the money, after ordering I was suffering with buyer's remorse ($175 is not exactly cheap) but once I put them in I was very happy I got these bulbs.
Even tho the bulb require some time to become milky white, I like the color they put out initially as well and way better than the stock.
      07-23-2011, 07:05 PM   #33
bobblehead
bobblehead's Avatar
Drives: warp speed
^^ Nice info provided.
who says money can't buy happiness ? In this case, we have proof.
      07-24-2011, 09:09 AM   #34
BaLLzZz
BaLLzZz's Avatar
Drives: e92 335i
So For Stock xexon match JUST BULB REPLACMENT Has anyone gotten
GP Thunder Plasma-White H8, 8500K/35W Quartz Glass Bulbs ?
My understanding is that the stock xexon is 4150? Correct?
I have been looking for a week or two now for just the bulb replacment for the FOG BULB(h8 non ///m) not the stock XEXON CBI Bulb
Also if you have done this before have you found a good place to buy the h8 and/or the corner bulb?
Thank You In Advance
Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius and a lot of courage to move in the opposite direction. - Albert Einstein
01 e46 m54 - Current : 14 f10 n26 - Boring & Gone : 15 f30 n26 - Current : 08 e92 n54 - Gone & Missed!!!
      07-24-2011, 09:31 AM   #35
bobblehead
bobblehead's Avatar
Drives: warp speed
I had the GP Thunder H8 before on my E60. Lasted about 9 months and the coating on the bulb started to peel off. Although the cost was about $25 + shipping. It was not worth the money. Besides, the 8500K is more of a purplish than whitish. Not really matching the headlight stock xenon light at all, but some will argue otherwise. My me is a disappointment of the outcome.
Here are couple of links for an online vendor that some bloggers over the e90post (3 series) have been buying from, prices are the typical MSRP and not discounted at all.
http://www.highperformancebulbs.com/h8bulbs.html
http://search.store.yahoo.net/racing...uery=(H8).html
      07-26-2011, 03:42 PM   #36
BaLLzZz
BaLLzZz's Avatar
Drives: e92 335i
First and foremost thank you for the response.
My question was and has been this.
HAS ANYONE ON THIS FORUM CHANGED JUST THE FOG BULBS(not retrofitted) JUST BULBS?
If you answered yes to that question ... What company/website have you used/bought the bulbs that match you STOCK xexons colorwise the best?
Thank You again
I want to order them asap but couldn't find osram and if stock is 4150 it would seem 8500 is to different BUT if a forum member tells me "NO thy match fine" obviously I'm going to confidently order a pair. Do you guys understand where I'm coming from?
P.S. Same exact thing for the Cornering Lights
      07-27-2011, 02:07 PM   #37
bobblehead
bobblehead's Avatar
Drives: warp speed
^^^ Here are some pics on the e90post.com forum to compare - changed out the stock fog H8 bulb for GP Thunder 7500K H8 bulb.
http://www.e90post.com/forums/showthread.php?t=513783
Hope that give you some idea on the after look
      07-28-2011, 08:34 AM   #38
BaLLzZz
BaLLzZz's Avatar
Drives: e92 335i
So the f10 guys who don't do a ballast retrofit type install of there fogs and onlybchange the bulbs have been going with gp thunder 7500 as the e9x crowd has?
Also any insight for the cornering bulbs pertaining to the company etc.
Thanks
      07-28-2011, 10:51 AM   #39
bobblehead
bobblehead's Avatar
Drives: warp speed
Yep! Just a simple changeover of halogen bulb for both the fog & cornering.
For cornering, you can go with GP Thunder as well with H7 type. That's if you like the look of the GP Thunder as illustrated. Do note the GP Thunder's coating will peel off after about 6-9 months of use and even if they don't peel off, expect life of abut 1 year to 1.5 year.
Here is a vendor sells GP Thunder
http://www.e90post.com/forums/showth...cornering+bulb
Thanks
      11-10-2011, 03:42 PM   #40
BD997
BD997's Avatar
30
Drives: 2011 Alpine White 550i M-Sport
D1S - if you are replacing, try Osram CBI .... no yellow tint to it.
$175 for a pair (US)
dont think they carry 8000K bulbs...
2011 550xi M-Sport (Alpine White)
      11-10-2011, 03:53 PM   #41
BD997
BD997's Avatar
30
Does anyone know if the high beam is D1S also??
      11-10-2011, 04:39 PM   #42
bobblehead
bobblehead's Avatar
Drives: warp speed
Same bulb. it's bi-xenon.
      11-19-2011, 08:49 PM   #43
BD997
BD997's Avatar
30
Just so I understand...
So in order for me to change the headlight bulb the car needs to be on a lift for EASIEST install?
      11-29-2011, 04:38 PM   #44
BD997
BD997's Avatar
30
Originally Posted by luigimaster24 View Post
Hey Alex!! I just switched my low beams on Monday with 5000k D1S bulbs. No more yellow tint like the stock xenons, just PURE white. They also match the angel eyes perfectly now.
Install is easy:
1- Jack up the car and turn wheel all the way to opposite side. ( You don't have to jack the car up, but it will definitely make it easier and save you from busting out hudini moves just to get in there)
2- Remove two screws to open the little door on fender lining.
3- Remove cover where the D1S bulb is located.
4- Make sure car is COMPLETELY off, no power going to headlights or anything.
5- Unplug the power plug connection located on the bottom of D1S bulb.
6- Twist bulb counter clockwise and remove.
7- Swap out D1S bulbs and re insert and re connect plug.
8- Put everything back together and repeat on steps on the other side.
9- Enjoy!!!
So basically there is an access panel to the headlight bulbs from inside each wheel well?
