2010 2011 BMW 5 Series Forum F10 Review and dyno results of BMW F10 535i GSR Technik Stage 1 ECU Flash tune |
06-11-2015, 02:29 PM | #23 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
06-13-2015, 12:02 AM | #24 |
Dream crusher
984
Rep 2,421
( ::::SERVICE UPDATE:::: )
Finally got the car back from the dealer. Almost 3 weeks in repair those a-holes. It went in for vibrating, pulling to the right and a cabin error related to seat positioning. The first call from them was their software crashed when trying to reset the ECU! They said they needed to reset the ECU for the seat error and a software update for the electronic steering that was causing the pulling to the right. I was so nervous thinking they were going detect something. They detected nothing. They blamed the crash on themselves saying their software tried to update itself in the middle of a reset(I call BS). I was like who the hell uses a computer to reset a DME while connected to the internet?! I informed Bobby of GSR and he mentioned that they shouldn't of had to reset the entire ECU. I got the car back and immediately noticed my flash was gone which means that crash forced them to completely reset it. It actually could mean two things 1. They fried the ECU and put a new one in. 2. They actually fully reset it. I went into GSR headquarters and had their techs replace the tune. We noticed that the ECU was the same. They could tell when they opened it up. During re-flashing they noticed that they placed new software on my board which is an older chipset. (2011 F10) This is actually good news! What this means is that the tune is completely undetectable to the dealer because they didn't fry the board and never noticed an adjustment to the existing DME. Now my car is back to being a monster and a GSR stage 2 is scheduled in a few weeks. BTW the GSR shop is amazing!
IG: @bmwdoubles |
06-13-2015, 12:14 AM | #25 |
Dream crusher
984
Rep 2,421
And just for good measure. Can you see the tune? No, no you can't nor can the dealer.
IG: @bmwdoubles |
06-13-2015, 08:35 AM | #27 |
Rep 14,522
Just curious? What happens with people who don't live in Cali that run into the same situation where the dealer needs to reset the ECU for whatever reasons? 2nd if I'm reading this correctly DP is recommended for better bottom end? Is a charge pipe and intake recommended as well?
06-13-2015, 11:31 AM | #29 | |
Dream crusher
984
Rep 2,421
The dealer has dumped thousands of dollars into my car over the course of 3 weeks trying to resolve my complaints. 3 brand new rims, control arms, bushings, front rotors and brakes, struts, road force balancing, alignment, 2 reflashes, labor, loaner cars and my personal time. Believe me if they could of detected it they would of stopped and said the car was tampered with and blame all repairs on that.
IG: @bmwdoubles |
06-13-2015, 11:42 AM | #30 | |
Dream crusher
984
Rep 2,421
Stock: 280whp 280wtq Stage1 + stage 2 prediction 323whp + 30whp 417wtq + 60wtq Could be more, nobody knows yet. The curve where power drops off might level out meaning it may not drop off so fast. They suspect it maybe the same just due to the way the car breathes, however the delta will be much larger guaranteed. I'm going to keep the stock exhaust and test with DP's and a stage 2 for the cleanest results. I was just thinking of a CP only because the the turbos are way more noticeable now and I am suspecting I will start getting leaks soon. Now she whistles while she works.
IG: @bmwdoubles |
06-13-2015, 11:48 AM | #31 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
06-13-2015, 12:29 PM | #32 |
Rep 14,522
Awesome! So as far as stage 1 did GSR recommend anything to be upgraded for this? I know exhaust will help let it breathe better but was wondering if doing the CP, DP and Intake would overall run the stage 1 at optimum tune?
06-13-2015, 01:29 PM | #33 | |
Dream crusher
984
Rep 2,421
A DP is going to give you an optimal tune at either stage. According to GSR the DP + tune will give you more power even with a stock exhaust over just a tune alone. They mentioned that an exhaust will give you a small bump mostly due to weight reduction.
IG: @bmwdoubles |
06-13-2015, 09:29 PM | #34 |
Rep 15
I would like to hear GSR chime in for out of state folks. Is a remote flash at all possible? All the kewl shit happens in Cali..
Glad to see some development on the previously locked out F10s! Any idea if GSR is researching any upgrades to the turbo as well? |
06-14-2015, 02:41 AM | #35 | |
Rep 244
Mike
'04 330i ZHP '11 535i |
06-15-2015, 12:32 AM | #36 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
those predictions are definitely a possibility! but expect huge torque increase in the lower RPM's, and a big drop off as it hits higher RPM's, its typical of the stock turbo on the N55.
what would be awesome is if you put a stage 2 turbo on it like my f30 you can do awesome things like this. ( this is still deep into development, but the dips are from my tires slipping on the dyno)
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
06-15-2015, 01:29 AM | #37 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
06-15-2015, 09:42 AM | #38 |
Rep 14,522
Getting big power is great but how much power can the stock n55 take before things start to break down? How much boost can the block handle? Is the factory fuel system adequate enough Maybe I'm old skool but a stock motor can only handle So much before u have to start upgrading the internals? It's great that the GSR tune will work great on a stock motor and I'm all in when it comes time to go with a tune.
06-15-2015, 10:31 AM | #39 |
515
Rep 1,063
Lol yea I forgot i was in the F10 thread when I said that. Im running a single Pure Stage 2 turbo, with JB4 and all the stuff in my sig, the two graphs that have Euro on them have a little bit of flash tuning included also.
06-15-2015, 10:35 AM | #40 | |
515
Rep 1,063
The dyno above was at 22psi, but we've taken it to 24psi with no issues. This is also Eurocharged doing the flash tuning, they've flash tuned quite a few F30's in the US and Canada already and are making more power than GSR's flash. They're just another option if your not close to Cali.
06-15-2015, 02:32 PM | #41 | ||
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
06-15-2015, 05:09 PM | #42 | |
515
Rep 1,063
06-15-2015, 05:18 PM | #43 | |
Rep 14,522
06-15-2015, 09:16 PM | #44 | |
Rep 15
Thanks for passing along his info. I just emailed him and will regurgitate his response. This would be great for me since I'm in Houston as well.
