2010 2011 BMW 5 Series Forum F10 I am considering the 20% discount on offer... |
11-17-2010, 07:31 PM | #1 |
Rep 1,170
Drives: 2020 F97 X3M
from Dinan. Offer for the ecu upgrade ends December 31st 2010. Net HP gains (for those unaware) are 95hp (495hp) and 123 lb/ft (573 lb/ft torque). Xdrive models excluded for now. Also according to the Dinan rep in the unfortunate event that warranty work is required, when dealing with an authorized dealer the warranty process is transparent (i.e. no money out of pocket to wait to be reimbursed). Although as we all know if something should arise there will most asuredly be some back n' forth between the dealer and Dinan for responsiblity.
Word is the TTV8 is conservatively tuned, and the increase in boost is well within the tolerance limits without having to go to a bigger intercooler and/or radiator, oil pump. If i should move forward to carryout the software upgrade it will be performed at Braman BMW West Palm Beach, FL an authorized Dinan Center. I still will retain the sleeper look, I may ditch the runflats for conventional High Performance tires and a mobility kit. Decisions, Decisions
2011 MINI CooperS BRGII/Lounge Green/Sport/Prem/Connect/Black Xenon/Black Conical Spokes/ACS springs/ACS exhaust/Alta Shorty/Yokohama Advan Sport A/S
2012 M3 AW/FR NDH2/2MK/ZPP/ZCP/ZCW/752/6NR/OEM CF splitters/OEM CF Mirror caps (retired) 2012 X3 35i Titanium Silver/Black ZAP/ZPP/TECH/APPS/Breyton GTS (retired) 2018 X3 M40i BSM/Oyster/ZPP/ZPX/HK/S6CPA/718M(retired) |
11-17-2010, 11:48 PM | #2 |
Rep 28
How will the additional power benefit the car's performance? driver enjoyment?
2012 Porsche Boxster S Black Edition
Spt Design pkg+19, PDK, Nav, XM, Red seatbelts. 2010 BMW GT 550i (F07) Euro Delivery Blue/wht+blk/ceramic. Spt pkg+20, Seat, Camera. |
11-18-2010, 12:35 AM | #3 |
Rep 1,087
only 550s?
11-18-2010, 06:38 PM | #4 | |
Rep 1,170
I was going to do it today but Dinan has not completed the coding for the GT, as it is different from the F10 sedan. The rep thought I had an F10. Apparently each car has a unique coding algorithim i.e. 750i code is different than 750 li. Dinan states that they should be done within a day or so. I guess I may end up being the first GT with the Dinan ECU upgrade.
11-18-2010, 06:41 PM | #5 |
Rep 1,170
Yes for now. But I am 100% sure they are working on something for the N55 engine which your car has.
12-23-2010, 05:47 PM | #6 |
Rep 158
Dinan just listed the F07 on their website. I am going to go ahead with it on Monday - can't wait.
I realize there are other/cheaper options out there, but the warranty coverage is incentive enough to go with Dinan. |
12-24-2010, 12:14 AM | #7 |
Rep 1,170
As I stated on 7Post thanks for the headsup! I didnt get the call that the software was available. I as well, will be at the dealer on Monday
12-29-2010, 10:28 PM | #8 |
Rep 1,170
Finally, Dinan Stage 1 reflash done. Guys if you want a bit, make that "Quite a Bit" more power, go for the reflash. Do it before the 31st and take advantage of the savings (roughly $600.00). You can "definitely" feel the difference. I suggest you leave DTC engaged
12-30-2010, 11:16 AM | #10 | |
Rep 1,170
Dinan has also extended the discount through Jan 31, 2010 purportedly due to demand
01-06-2011, 08:16 PM | #12 |
Rep 1,170
Whats the status?
01-07-2011, 12:09 AM | #13 |
Rep 158
after waiting for 2.5hrs at the dealer, the service adviser tells me they "don't have the wire" to connect to the new OBII plug DINAN provided them. he added they spent all this time trying to get the older plug to communicate with my car, but it didn't work...
needless to say, i will be re-doing the dyno runs once the dealer is finally prepared. till then: 1- best baseline hp #s were produced in 5th gear! 2- highest hp # was 323hp. consistent #s between 321-323hp range produced for all pulls. (meets my expectation of 20% loss from 400 crank hp) 3- tuner shop owner was impressed with the consistency, as air boxes are located right above the turbos. he was concerned about heat soak. |
01-07-2011, 09:33 AM | #14 | |
Rep 1,170
BTW: I do wonder how the 750i Edmunds dyno'd produced something like 390 rwhp -stock
01-07-2011, 06:49 PM | #15 | |
Rep 158
Also, i am using a Dyno Dynamics load-bearing dyno. It is known to give lower (and some say truer) #s than say dynojet and dynapacks. This, i believe, is shown in the consistent #s range from the pulls - (which fall within the estimated 20% loss from quoted crank hp) this is where I am having it done: http://www.gocpt.com/dyno.php I just finished talking with the DINAN rep. He will be talking directly with the dealer to correct any installation errors they have, prior to my arriving for the upgrade. Dinan has great customer support! |
01-07-2011, 09:07 PM | #16 | |
Rep 1,170
01-08-2011, 02:39 PM | #17 |
Rep 226
Avus your a genius! I've been dying for someone to do a dyno before and after of the Dinan install. I was supposed to get my 550I on the 12th of this month but BMW screwed up and now I wont get it till february. I had already scheduled the install and was planning on doing a before and after but I'm glad to see someone beat me to it. I hope you post the results soon I'm dying to see the difference. And your right on a Dynojet you would have gotten a significantly higher number but its irrelevant. All we care about is seeing the increase in power on the same machine. Great job and how about posting the chart?
01-09-2011, 07:23 AM | #18 |
Rep 158
I am hoping on Monday DINAN can rectify any errors the dealer has with the installation process. Thus, I'll schedule the dyno and software upgrade for Wednesday.
Once complete, I'll post up all #s and graphs. |
01-09-2011, 07:35 AM | #19 |
Rep 5
just text,see hello to everybody
