2010 2011 BMW 5 Series Forum F10 Quick video clip of my 550i and the resonator delete I had done |
05-08-2020, 11:13 AM | #1 |
Rep 116
Figured I'd share since there are not too many videos of 550i's out there. Had the back resonator deleted this morning to get slightly more sound of the exhaust. It's still pretty quiet and I may go with a muffler delete eventually. But for now it gives just a bit more aggressiveness. I also have the exhaust valves ziptied open.
Quick walkaround of the car:
2015 Estoril Blue 6-Speed M235i
05-09-2020, 08:44 AM | #2 |
Rep 14,521
Aren't those resonators up front?
06-04-2020, 03:17 PM | #3 |
Rep 116
The resonator is in the middle, before the mufflers. Up front are the downpipes and secondary cats before them.
06-07-2020, 06:32 PM | #4 |
Rep 262
Sounds good. I started with muffler delete then went back and did X-Pipe and got rid of everything under the car.
I might need mufflers soon after I install CL DP's because I'm sure the drone will eventually drive me nuts but since I never hear it over my system I can't complain.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
06-09-2020, 09:30 PM | #5 | |
Rep 116
06-17-2020, 09:38 PM | #6 | ||
Rep 262
Muffler Delete (11 months ago) X-Pipe with Resonator and Muffler Deletes (2 weeks ago)
2011 550i (N63)
06-18-2020, 11:50 AM | #7 |
Rep 116
That sounds great! Will have to do that myself as well. Quick question, what size exhaust tips did you go with? So many out there with different inlets and outlets.
