2010 2011 BMW 5 Series Forum F10 ACS springs on luxury line |
06-08-2017, 10:59 AM | #23 | |
Rep 1,154
06-08-2017, 02:43 PM | #24 |
Rep 697
Drives: 2013 535xi
Thanks.
I think so too! I wasn't actually expecting it to be that much, but it's all good. Thanks, and good to know that the rear might settle some more.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
06-11-2017, 05:41 AM | #25 |
Rep 697
Drives: 2013 535xi
A better picture showing the drop. The front is not quite that low, but the ground is a bit uneven there. Cheers.
While I'm at it, here's a picture of my wife's car. It is a 2010 E89, completely stock. She likes it that way. I just polished it and applied Wolfgang's Uber Ceramic Coating yesterday.
lsturbointeg9151.00 |
06-11-2017, 06:43 AM | #26 |
Rep 14,522
The drop came out pretty damn NICE! the E89 looks pretty clean too! i'd do a mild drop on that thing with ACS just to give it some oooomfff!
07-24-2017, 12:21 AM | #28 |
Rep 697
Drives: 2013 535xi
BLUF (Bottom line up front): ACS springs and the dynamic suspension work very well together.
I have the dynamic handling package with both the dynamic damping (shocks) and the active role stabilization (sway bars). My 535xi handled quite well without the ACS springs and cornering was relatively flat for this heavy car. I'm not trying to compare it to a 3 series or something else lighter, mind you, but it was not bad. You could still feel the weight with the mild but predictable understeer. Now, with the ACS springs, handling is more responsive, and the car is even more composed on tight corners. I would not say that the ACS springs transformed the ride, but they certainly improved the handling. On a mildly negative side, the ride is a little harsher, as expected. While the ACS springs do transmit more of what both the roads and wheels are doing to the rest of the car (which I suppose is the entire point of sport suspension), I can now feel more bumps and and I can also feel some mild wheel damage that I experienced on some hideous potholes a few months ago.
Bruno11219.50 |
07-24-2017, 10:32 AM | #29 | |
Rep 107
07-24-2017, 12:45 PM | #30 |
Rep 697
Drives: 2013 535xi
My car is pre-LCI, and the ACS springs dropped the rear by about 1.2 inches / 30mm, and front by about 1.5 inches / 38mm. I recently had my mechanic check that the right parts were installed in the right places, as the drop was more than I had expected. He confirmed it to be per the ACS parts list on their web site for a 535xi.
Bruno11219.50 |
10-26-2017, 09:06 PM | #31 |
Rep 8
10-27-2017, 10:26 PM | #32 |
ZEROdoubleZERO
228
Rep 659
My rears rub, but only because forgestar f&@kd me(long story) and sold me the wrong offset(+32's). You wont have any rubbing issues if the wheels you plan on using have the correct offsets. I would not reccomended 20x11's on the rear unless you can get them in a +46 offset. When I replace the rear wheels Im getting a 20x10.5 +40 on the rear and using same fronts. The 295 will fit a 10"-10.5" better than an 11", I have some tire stretch on the rear that doesn't match my fronts. My original tire combo was 275's upfront and 305's on the rear, and they were "square" as in no tire stretch, but the 305's rubbed bad so I put 295's 2 days later. I hope all that makes some sense to you, I'm here if you need more info.
