2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Daytime Running Lights
      09-07-2011, 06:04 PM   #23
joy5
Drives: xDrive30d M Sport
Originally Posted by PoleApart View Post
Mine are on when on 0
What's yours... Halogen or Xenon?
2013 - x30d E70 M Sport
2010 - 520d F10 SE
      08-14-2012, 07:19 AM   #24
pxdspain
Drives: 520 D ED
I have the same issue with the DRLs on my car in Spain - I only have the Halogens. It seems that BMW have fixed this for the new 1 and 3 series, as I have seen a lot of them here, driving with just the Corona rings lit, no dipped beam or rear lights on. Pity they can't do the same for the 5 series ...
      08-14-2012, 10:47 AM   #25
gspannu
Drives: F10 535, F82 M4
The DRL lights behaviour on F10 can be coded.
If you have halogens and only want your 'Angel Eyes' to turn on when DRL is checked; it is possible.
You can code your car and choose from various options:
a) Angel Only
b) Angel with Rear
c) Angel with Halogen (which most people have)
d) etc..
A similar set is also available with Xenons.
I have recently programmed both in 2 different cars. My own car is Xenon and I changed some of the behaviour.
The other car was halogen and he had Angels+Low Beam and we converted this to Angels only.
So, in a nutshell; definitely possible via coding using E-Sys.
      08-14-2012, 01:03 PM   #26
A900ss
A900ss's Avatar
Drives: 2012 520d Touring
a) Angel Only
b) Angel with Rear
d) etc..
Really? Very interested in just having Angels only on my halogen set-up. How do I go about doing this? I assume this s different to just turning on the sidelights.
      08-14-2012, 04:15 PM   #27
gspannu
You need to code your car using E-Sys.
The parameters are in FRM CAFD module/ 3050 - The parameter is DRL_MODUS and possible values are
nicht_aktiv / drl_h / drl_l / drl_s / tfl_s / tfl_ece / tfl_s / drl_s_ohne_sl / tfl_s_ohne_sl
I presume you are familiar with coding...
      08-15-2012, 05:47 AM   #28
A900ss
A900ss's Avatar
Ummmm No.
Think I'll leave it where it is...
Thanks anyway.
      08-16-2012, 01:26 PM   #29
gspannu
Ummmm No.
Thanks anyway.
Fair comment. If you are ever around my area, Hampshire Basingstoke, Winchester- give me a shout and I will do it for you.
      08-16-2012, 08:30 PM   #30
SamS
Drives: Tesla M3 Perf + '18 X3 M40i
Hope it's OK to ask in this existing thread, because something has been bugging me about some F10's I see here in the US.
Most of them have the LED DRL. However, I have seen a few, that appear to have halogen DRL on the inner headlight. Why is this? I can't tell if the car has the standard LED DRL, because it is usually driving when I see it. It always stands out to me, because I either expect to see Xenons + dimmed LED DRL, or just the LED DRL corona rings lit up.
      08-17-2012, 02:28 AM   #31
gspannu
Not seen such a thing here in UK, so cannot really comment...
      08-17-2012, 02:48 AM   #32
smanoj77
smanoj77's Avatar
Drives: bmw m240i
are you able to code them to make the halos brighter? Someone has already done it as mentioned in this post http://f10.5post.com/forums/showthread.php?t=708039
      08-17-2012, 07:52 AM   #33
AP
AP's Avatar
2782
Drives: G30 M550
reduce main beam as DRL's is one of teh options.
I was recently in Laos and saw a F10 there with that option set, didn't look great.
If you look at the F10 cheat sheet (goole it from these forums) you'll see tehre are lots of options as mentioned earlier on thsi thread
there are 8 options for DRLs
so pasting form that doc they are
0: DRL disabled;
1: DRL_H via beam, halogen U.S. (without lights);
2: DRL_L via low beam;
3: DRL_S via separate TFLeuchte; U.S. Xenon (rings +
bottom);
4: TFL_S via separate TFLeuchte; ECE Xenon (rings + bottom);
5: TFL_ECE (North Country Comfort);
6: DRL_S_ohne_SL via separate
TFLeuchte without taillight / tail lights, U.S.;
7: TFL_S_ohne_SL via separate TFLeuchte without tail light / rear light, ECE
So I imagine the one you saw must have been option 1 I would assume.
      08-17-2012, 08:49 AM   #34
SamS
Browsing through some threads, it seems like for MY2011, there was a "halogen" option, or maybe LED halos + Xenon was an upgrade or part of a very common package?
      07-23-2013, 03:20 PM   #35
poolie
Drives: bmw 520d f10 m sport
a) Angel Only
b) Angel with Rear
d) etc..
Hi im busting to get this done on my car. Ive asked bmw and even been around some independent bmw specialist with no joy since reading this post a couple of weeks ago. Were can I get this coder and is it straight forward enough to do. Ive no experience in anything like this. My car is a f10 with halogen lights.
Really appreciate it if you can help. Thanks in advance.
      07-23-2013, 03:40 PM   #36
gspannu
If you do not understand coding, I would not recommend trying it yourself. E-Sys is a complex bit of software and you can inadvertently damage stuff (if not careful). This is not to discourage you, but just being realistic.
If you are ever around the Hampshire area (Basingstoke, Winchester) give me a shout and I will do it for you.
Alternatively, try and find a coding expert near your area.
If you still want to try and code it yourself, then try reading this link and see if you are game. http://www.bimmerfest.com/forums/sho...d.php?t=631884
      07-23-2013, 05:08 PM   #37
poolie
Thanks for the swift reply mate.. looks to complicated for a roofer
Thanks for the offer too. But I think were doing east anglia for hols this year or would of popped down shame it wasn't last year as we were in Weymouth
Can you direct me give me some sort of idea as to who could have this equipment? Im presuming its not just for bmw. As ive said spoke to some independent s but they cant do it much appreciated and thanks
      07-24-2013, 01:39 AM   #38
AP
AP's Avatar
2782
Drives: G30 M550
I don't believe the dealers have this software at all. I believe its only used at the factory and presumably specialists within BMW. My local dealer has not even heard of the software. You'll need to obtain the software and get (or malke) a cable. I did this and after following the guides found online, did some very basic coding.
      07-24-2013, 03:04 AM   #39
poolie
How much is it likely to cost? My brother might be able to do this for me.
      07-24-2013, 06:34 AM   #40
gspannu
Cable/ Connector: £10-£15
Software: Free
Other requirements: Patience and a steady hand
      07-24-2013, 12:27 PM   #41
AP
AP's Avatar
2782
Drives: G30 M550
I was nervouse the first (and only to date) time I coded but as long as you follow the instructions carefully, its fine.Mine worked first time without any issues. (I coded the stop start to be last setting whifh is about the easiest change you can make, its just one single change)
There are others on this forum far more experienced than me but its not too bad.
You'll obviosuly also need a laptop with I think from memory around 45Gb of free space . Its quite a large amount of code and data.
      08-05-2013, 08:56 AM   #42
poolie
Software: Free
Hi again mate. A friend mechanic is going to do this for me he's got the software just waiting for the cable.
As mentioned in this thread can the angels also be programmed to look brighter?
      08-05-2013, 09:57 AM   #43
gspannu
Short answer seems to be No.
I have read many forums talking about this, but the values are already set to 100% - so they cannot be made brighter.
The coding does exist... but maybe it is for older or other variants where the value is not set to 100%.
      08-05-2013, 10:26 AM   #44
poolie
Thanks pannu for your help and quick replys much appreciated.
