2010 2011 BMW 5 Series Forum F10 Subwoofer cuts out when turning up volume |
08-17-2017, 11:01 PM | #1 |
Rep 70
Installed a Technic harness with a LC2i, Accubass is disabled, gains are set to the lowest position on the amp and LOC. No bass boost etc. but when i turn up the volume and the bass hits the new sub cuts out. I know the sub and amp work perfectly fine in my other vehicle. But when the volume gets past 1/4-3/8 the sub will cut as soon as there is a heavy bass hit. Anyone have similar issues?
Top hifi Technic Harness with LC2i Image Dynamics SQ1200 amp Single 12" Image Dynamics IDMax |
08-18-2017, 04:11 PM | #2 |
Rep 14,522
off topic but DaHeadlightguy what are you running for components and are you running an amp for those?
08-28-2017, 02:13 PM | #3 |
Rep 106
"Sub cuts off"
Check if the Amp is going into 'Protect' mode. If yes, check if the sub is wired correctly and for the right load (ohm/resistance). You might have accidentally wired the sub for a lower load resistance than the amp is capable of handling (I am assuming it is a DVC sub). I hope this helps. |
08-28-2017, 02:17 PM | #4 |
Rep 106
2nd -
Check all connections are tight (all speaker/ woofer/ amp power and ground). Sometimes, when the load increases and the connections are not tight enough (or have corrosion), the connection breaks when a huge load is drawn (volume increased). |
