2010 2011 BMW 5 Series Forum F10 Shifter returns automatically |
08-12-2015, 02:36 AM | #1 |
Rep 26
Next time you're driving in Sport, just shut off the motor after you bring your car to a stop. After a second, a little motor will move the shift lever back to the right!
08-12-2015, 10:54 AM | #4 |
Rep 14,522
Yeah...I noticed that when I first got the car. I accidentally turned the car off in sport mode and it shifted over to park automatically... pretty cool and dummy proof!
08-12-2015, 11:09 AM | #5 | |
Rep 1,684
This is why you can put it in sport mode by shifting the sport gate, hit stop, and the car will politely shift into park. Without the kinetic movement, the car would not be able to shift into park upon powering off the car. Well, at least the shifter would not be in sync with the state of the car. This is also why the shifter pops back into the neutral position after shifting into "D". The concept is called stateless. BMW got it right. But, many American cars goof it up. Your knob for the main volume control is stateless. You cannot tell what the volume level is by looking at the knob---for the same reasons. This way, the volume can be controlled by more than one source. Or, upon entering the vehicle, the volume can be lowered based on a profile preset. Ever notice when you come home in your bimmer with the speakers throbbing that on the next morning the levels are reduced? By keeping the shifter stateless, BMW can control the shifter by more than one source. If you open your door, with the car in drive, and your foot on the brake without your seatbelt (in some cars), taking your foot off the brake immediately shifts the car into park. Stateless baby. Professional audio mixing consoles take the stateless to a new level. The faders will kinetically move into position based on saved settings, most other knobs are stateless. This way, you can control the mix from your computer or the mixing console. In short, stateless allows control to be handed to more than one source. |
08-12-2015, 08:36 PM | #6 |
Rep 26
Thanks everyone for the replies.
"Stateless." That makes a lot of sense. I have wondered about this when I switch on reading lamps in a jet; can the pilot turn all lights off from the cockpit without the crew having to go row-by-row and return settings to "off" after parking the plane? |
08-20-2015, 02:07 PM | #8 |
Rep 554
Interesting. I also noticed that it pops back into park when you try to drive off with the door open. I was trying to pull into my garage with the drivers side door slightly open and it just wouldn't let me, kept on switching back to park.
08-22-2015, 09:58 PM | #9 | |
Rep 1,684
You see, air crash investigators typically rely on the position of switches and gauges. For example, there is even a term for this called "witness marks." Witness marks are caused by the paint on an analog gauge's needle striking its clear protective surface after an impact. The witness marks can aid the investigator by conveying where the needle was at the time of impact. Of course this doesn't always work in modern glass cockpits. But, even modern cockpits have basic gauges in case the glass (display monitors) fails. Finally, even older aircraft have updated passenger compartments. So, you provide a fine example on how stateless buttons may work on some aircraft. |
08-23-2015, 08:51 AM | #10 | |
Rep 6,863
08-23-2015, 09:14 AM | #11 | ||
Rep 1,684
The second you take off your seatbelt, the car will pop into park. |
08-24-2015, 01:18 AM | #12 | |
Rep 14,522
12-29-2015, 07:30 PM | #13 |
Rep 80
Question
On my 2012 if my seatbelt is engaged it wont do that (go auto into park) with the door open
But on another Note Ive gotten pretty used to just hitting Stop when im parking, and i like the automatic into " Park" feature Am i screwing up anything? do i really have to put it in park like a Normal car? What do you guys do? or is this another if so i missed it
2001 530i
2004 330i 2006 X5 4.4 the beast 2014 328i 2012 535i |
12-30-2015, 03:39 AM | #14 | |
Rep 1,597
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
12-30-2015, 10:36 PM | #15 |
Rep 80
mine doesnt put on any brake, if i want the emergency brake on, i need to pull it up, but thanks for the clarification on the stop start
2001 530i
12-30-2015, 11:52 PM | #16 | |
Rep 5,365
12-31-2015, 05:23 AM | #18 |
Rep 5,365
12-31-2015, 08:05 AM | #19 | |
Rep 29,202
If I don't have Auto H on, I have to pull up the handbrake button to engage the handbrake.
12-31-2015, 09:50 AM | #20 |
Rep 5,365
12-31-2015, 10:11 AM | #21 |
Rep 15,858
