2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Sport vs. Sport?
      12-23-2015, 05:21 PM   #1
carnut65
Drives: 535i Xdrive MSport
Sport vs. Sport?
Quick check. Is Sport program activated via center button = Sport program activated via center selector lever push to the left? Exact outcome? Thanks.
      12-23-2015, 07:03 PM   #2
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
I believe that the Sport setting via the center console button changes the weight of the steering, throttle sensitivity and transmission shift points.
Moving the shifter to the left only changes the transmission shift points.
      12-24-2015, 06:42 AM   #3
HighlandPete
Drives: BMW F11 535i Touring
Yes the sport mode has all the variables as you say, according to how the car can be configured. Shifter to M/S is simply the gearbox program, even that is different to the sport mode drivetrain program.
For example, in my 535i using sport mode (Drivetrain checked) and then moving the shifter to M/S, typically drops a further gear. It's as if sport mode is a half-way mode to full Sport gearbox function.
HighlandPete
      12-24-2015, 07:02 AM   #4
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
Yes I've noticed this too
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
      12-24-2015, 06:53 PM   #5
snowmuch
Drives: 2016 Macan Turbo
What about S+ vs S (drive train and chassis)? the only difference is the traction control?
C300->C63->535->S4->M4->Macan->Macan Turbo
      12-24-2015, 11:14 PM   #6
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
Yes, I believe the only difference in Sport+ is that you turn off traction control.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      12-25-2015, 05:37 AM   #7
HighlandPete
My car, the same happens in Sport & Sport+ modes. Say I'm in Sport mode (drivetrain & chassis checked) the gearbox has already dropped a gear for higher shift points when switching to Sport mode. If I move the shifter to M/S it typically drops a further gear.
If I'm in Sport mode with shifter in D and toggle to Sport+ DTC activates, no other change. If I then move the shifter to M/S the gearbox drops a cog.
The gearbox dropping a further gear is not a constant, it depends on road speed/rpm, but it is clear shift points have moved up to a higher rpm due to using the M/S program.
HighlandPete
      12-25-2015, 08:14 AM   #8
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
I have passive suspension so no changes there on my car, but the car feels the most sporty when both the drive mode and transmission are in sport rather than just one of them.
      12-25-2015, 11:55 AM   #9
snowmuch
HighlandPete
Thanks!
