2010 2011 BMW 5 Series Forum F10 F10 M5 Downpipes on 550i |
09-25-2015, 01:40 PM | #1 |
Rep 736
What kind of gains would one see in performance and sound if I installed the stock f10 m5 downpipes on my 550?
Are they any less restrictive than the stock 550 downpipes ? |
09-25-2015, 07:08 PM | #2 |
Rep 43
Looking for some info on this as well. Going to be installing the M5 exhaust, not sure if it's worth looking into adding M5 downpipes also.
Brian |
09-25-2015, 09:53 PM | #3 |
Dream crusher
984
Rep 2,421
I don't think you'll see any gains. Grant it I have the n55, but I only saw an increase in the top end on mine with a VRSF because I already have a tune. I'm almost positive you would have to dial in a tune to take advantage of any DP.
Additionally, it didn't free up the spooling as much as I had hoped. What really free the spooling and gave better throttle response was the combination of DP and my new hi flow exhaust.
IG: @bmwdoubles |
09-26-2015, 01:21 AM | #4 |
Rep 436
M5 OEM Down Pipes
Check my post; http://f10.5post.com/forums/showthread.php?t=1169845
Bone Stock OEM 2011 550i Dyno 379 WHP. OEM M5 Down Pipes with NO TUNE 409 WHP a gain of 30WHP combined with a growling deep exhaust note. When combined with OEM M5 Down Pipes and OEM M5 Exhaust NO TUNE 424 WHP an additional gain of 15 WHP however lost the beautiful growling deep tone to an obnoxious loud raspy exhaust ( I hadd to add 4 additional resonators to regain the previous tone). The above hardware combination along with Burger Tuning JB Stage2 piggy back and pure 100 Octane+Torco 497 WHP an additional gain of 73 WHP. I believe this setup is easily above 500 WHP if I were to eliminate the additional resonators but not a valid trade since I love the way this V8 engine deeply and graciously growls. Good Luck Last edited by 747flyboy; 09-26-2015 at 05:51 AM.. |
09-26-2015, 01:41 AM | #6 |
Rep 436
Turbo sound
A very subtle turbo whine only audible during gear shifts. No sound clips since I am no more than 50Db. Maximum. It is a natural V8 quite tone at low to Mid RPM that gradually increases to sporty tone at higher RPM.
09-26-2015, 01:55 AM | #7 | |
Rep 736
09-26-2015, 02:13 AM | #8 |
Rep 436
Down Pipes
I refrain from using custom shops to do anything on a car. They are full of Boloni when it comes to promises. BMW spends hours on engineering wind tunnels science and airflows to best manufacture effective components versus some welding shop with local ideas. Just think of the next better component an OEM has to offer if you were to ever upgrade. Short answer, YES and not to mention CEL and other complications. A perfect fit since Turbos exhaust outlets of both 550i and the M5 have the same 22mm outlet diameter. You may have to shave off a bit one of the mounting M5 DP's since it slightly protrudes on the area of the starter motor.
09-26-2015, 01:58 PM | #10 | |
Rep 736
Do the m5 DP hiss like catless downpipes, how would you compare the two ? What other changes in the exhaust did you do ? |
09-26-2015, 02:19 PM | #11 | |
Rep 844
So in short, if you want clean emissions, then yes, chances are there isnt much improvement available over stock, however if youre after power, then there is a TON of room for improvement on EVERY part of that car, ESPECIALLY in the computer.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
09-26-2015, 09:21 PM | #12 |
Rep 436
M5 DP's
Attached a diagram of both 550i (left side of diagram) and M5 exhaust manifolds and a diagram of the Down Pipes. Down Pipes are a perfect fit as you may see the identical diameter of both Down Pipe Inlets (however the body of 550i Down Pipes are more restricted due to 600 CPI or Cell of Ceramics per Inch versus the M5 200 CPI, M5 Down Pipes Tubing/Ducts are wider and more of a free flow) since Garrett/BMW opted to use identical Turbine and Turbine Housing section for both 550i and M5 Turbos but totally different Compressors and Compressors Housing section. Meaning M5 Turbos and 550i Turbos are not cross compatible unless the Exhaust Manifold is also changed. M5 Exhaust Manifold is cross banked (Cylinder 1,4,6,7 feed rightTurbo and Cylinder 2,3,5,8 feed leftTurbo) a genius BMW concept maximizing on firing sequence and the four cycle of a combustion engine at mid to high RPM the Turbos are in a continuous spool. The M5 Turbo Compressors rotate counter clockwise in opposing direction to meet the cross banked Exhaust Cycle. 550i left exhaust manifold feed left Turbo and right to right. Turbos rotate in the same direction. Sound is more apparent and aggressive, however no hissing. I hope this helps.
On a separate Note; Alpina B7 Turbos share same Turbo housing as 550i but have different internals such as Compressor Exducer and turbine wheel. They are rated at 507 HP vs. 402HP on Garrett Honeywell website and are a perfect match for 550i. About to install on my 550i. I will keep you all posted. Last edited by 747flyboy; 09-28-2015 at 06:12 PM.. |
09-29-2015, 05:23 PM | #13 | |
Rep 736
Also, if the stock f10 m5 downpipes fit on the 550, would aftermarket m5 downpipes fit as well? Thanks for your responses . |
09-29-2015, 11:42 PM | #15 |
Rep 1,407
10-01-2015, 10:02 AM | #16 |
Rep 738
after searching around, 2010 - 03/2011 built date is flange style
04/2011 + is slip fit Sadly I am 12/2010, so M5 DPs would not fit, was really hoping to do this swap too ...
2011 550i
2013 M5 2014 M5 CP 2016 550i |
10-01-2015, 10:17 AM | #17 |
Rep 844
nothing an exhaust shop can't fix.
10-01-2015, 10:31 AM | #18 |
Rep 243
10-01-2015, 11:15 AM | #19 |
Rep 738
oh ? does it refer to the end side or the turbo side ? I thought it meant the turbo side, if its the end side then yes a shop can probably work with it
2011 550i
2013 M5 2014 M5 CP 2016 550i Last edited by 550Reasons; 10-01-2015 at 11:24 AM.. |
10-01-2015, 01:19 PM | #20 |
Rep 46
Mine is a 12/10 build date as well. but if we go with M5 downpipes and a full M5 exhaust, from what I'm reading that all will be well. I'm seriously considering this full swap. I just wonder what havoc it'll cause at the dealership if I have a warranty issue.
10-01-2015, 04:26 PM | #22 |
Rep 46
How's that setup sounding?
2011 550ix M-Sport/Carbon Black/Black Grills w-TriColor/18% 3-M tint/CF Performance Spoiler/Coded/ Philips 5000K fogs/CF side turn cover/Painted Reflectors/20" staggered BMW 356's/BMS 15mm rear spacers/BMS Stage 1/M5 Exhaust/Custom Ram Air
