2010 2011 BMW 5 Series Forum F10 Alignment same for all F10? |
12-26-2015, 07:04 PM | #1 |
Rep 154
Hey guys...
I got an alignment today for my car since there was different camber on my rear wheels. This made the wheels look more uneven after I installed my new spacers. They did a great job fixing the camber but I noticed the spec sheet said "2012 BMW 535 non sport suspension". This is the setting selected by the tech and used for the alignment. Would the machine have a different set of numbers for my car which is actually a 2013 msport/sport suspension with 19in wheels? Last edited by f10inSD; 12-26-2015 at 07:33 PM.. |
12-27-2015, 12:29 AM | #2 |
Rep 14,521
I would think so? Give them a call just to be safe
12-28-2015, 10:19 AM | #4 |
Rep 18,716
@f10inSD as long it is the same chassis, the alignment specs are the same.
12-31-2015, 08:33 PM | #5 | |
Rep 9
01-01-2016, 05:24 AM | #6 |
Rep 15,858
01-11-2016, 05:56 AM | #7 |
Rep 1,873
I would expect the alignment specs to change with ride height. If for no reason other than some settings cannot be adjusted and will change with suspension compression, so a new "OK" range would need to be set.
If your F10 has "non-sport" ride height the. You are probably fine. If it doesn't then you should inquire. |
01-11-2016, 01:51 PM | #8 |
Rep 2,072
On Hunter/KDS alignment machines, there are different profiles for M sport and non-M sport suspension cars.
Different ride height would alter the alignment specs. |
