2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 550xi making horrible noise on startup!
      01-12-2016, 12:47 PM   #1
lofrese1
Drives: BMW F90 M5
Hi Guys on my F10 550xi for the past week every time I start the vehicle in the morning it makes a grinding noise after the vehicle turns over. It only has been happening since the weather has been 30degrees or below. I've had the ccp package done a few months ago and about two months ago had the spark plugs changed under maintenance. The vehicle currently has 44k on the dash I was wondering if anybody else experienced any problems like this? Thanks.
      01-12-2016, 01:33 PM   #2
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
I would definitely take it in since it's still under warranty. A grinding noise can never be good.
      01-12-2016, 02:19 PM   #3
belal242
belal242's Avatar
32
Drives: 11 F10 550xi
2011 550xi  [0.00]
I have had the same sound, and was only able to replicate it on overnight cold starts. The dealer was unable to re produce the sound and dismissed the issue. I am still CPO'd but I don't want to pay for a diagnostic if they can't replicate it. It's a frustrating issue. This is all before and after CCP, HPFP. I have a feeling it is the timing belt or some belt that has an issue on start up.
      01-12-2016, 02:23 PM   #4
550Reasons
550Reasons's Avatar
Drives: F10 550i
your starter, mine was doing same noise as yours (I think) and they replaced it under warranty.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      01-12-2016, 02:27 PM   #5
belal242
belal242's Avatar
32
2011 550xi  [0.00]
I'll have them look into the starter the next service.
      01-12-2016, 03:52 PM   #6
Pimpsy
Drives: 2019 M5C
Originally Posted by 550Reasons View Post
your starter
+1
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      01-12-2016, 07:05 PM   #7
SeeYa
Drives: 2019 X6 35i
I always thought this auto-start nonsense would wreak havoc on a starter. Heck, I think even the manual warns of additional wear due to auto start.
I'm in the habit of putting it in sport mode whenever I start, I need to get it coded to default to sport.
      01-12-2016, 09:52 PM   #8
Zer0Cool92
Drives: blue metallic
Mine does it sometimes as well. Gives that sounds like if you turn the key in the ignition when the car is already on. I'm out of warranty.. Wonder how much something like this would be to replace
      01-13-2016, 07:45 AM   #9
IBOOSTU
Drives: 19 M5 COMP/21 M5 COMP FROZEN
thats crazy i have the same sound with exact same mileage exactly like 44k miles and its making this same noise you describe , its like a longer start
      01-13-2016, 07:50 AM   #10
lofrese1
Drives: BMW F90 M5
The starter was replaced about a year ago. I couldn't imagine this would be a faulty starter already this is crazy. Time to make another appt with my SA again!
      01-13-2016, 07:53 AM   #11
lofrese1
Drives: BMW F90 M5
Yeah it's crazy. This morning it didn't make the sound but it took at least a few seconds before it turned over. Now I'm thinking maybe it's a fuel pump too. Very frustrating.
      01-13-2016, 08:14 AM   #12
The X Men
Drives: 2013 X3 35i
If it is a bad starter, shouldn't the OP's car make the grinding noise while it is cranking and not afterward?
      01-14-2016, 05:27 AM   #13
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
If the starter mechanism that engages the flywheel is sticky it may still be in position when it isn't supposed to be and make the grinding noise. Googling "bendix" may add some insight. From the description my first avenue would also be starter
