2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum trip preparation question...
      05-03-2011, 06:53 PM   #1
dpwr
Drives: a good one
so I'm planning a long trip with my f10 (about 3000 miles) and i'm going to do it on my 20's with hankook tires, now I'm thinking to take my 17" winter wheel just in case as backup, if something happens and I put on that 17" wheel, will it be fine? nothing will happen to alignment or to the suspension? or what would you advise ?
      05-04-2011, 01:13 AM   #2
delvek
delvek's Avatar
Germany
33
Drives: 2014 550i Msport
Personally, not into the 20's fad or even understand the reason for them but, more importantly, where are you going to put a set of 17" tires/rims in your car and still account for any luggage for a 3000 mile trip? Are you solo'ing it?
2014 550i M-sport
      05-04-2011, 01:22 AM   #3
raleedy
Drives: 2016 228i 6-speed
I think the op is proposing one 17" wheel as a spare. It should work fine. The circumference is the critical measure and it must be close to the same. Of course the car will not handle properly with one unmatched tire, so you would have to drive conservatively.
      05-04-2011, 06:31 AM   #4
Whteverjklasdf
Drives: .
wow... all i can say is... good luck. haha.
seriously, why don't you use a more suitable car for the occasion?
      05-04-2011, 07:21 AM   #5
ghueser
Drives: 2014 M5
Although you can certainly drive on one 17" Wheel, with the other 3.... 20's, but there is a chance that the car will throw some codes or warnings at you as a result of sensing the difference in rotation speed. I am not sure though if this will happen. You might want to send a note to Mike Miller at the car club and see if he knows.
      05-04-2011, 02:51 PM   #6
andyk500
andyk500's Avatar
Drives: F10 520d M sport Carbon Black
Why don't you give it a try before you go. Just swap a wheel on your normal trip to work one day?????
      05-04-2011, 05:38 PM   #7
dpwr
Drives: a good one
i rather ask before damaging anything
      05-04-2011, 05:59 PM   #8
bobblehead
bobblehead's Avatar
Drives: warp speed
If you don't bring your 17" as spare, at least BMW Assist can help you in some way. But at least bring an electric air pump & 2/3 cans of tire sealant.
      05-04-2011, 07:22 PM   #9
1HOT BMR
1HOT BMR's Avatar
Drives: Car-less and shopping +'12 35d
Just join the Auto Club and call them if/when you get a flat. I have a CSAA (auto club) membership and I carry a BMW jack, lug wrench, hi-power air compressor and a plug kit. All this stuff uses very little space at the back of the trunk. I don't need (or want) a spare in my trunk
      05-04-2011, 07:27 PM   #10
dr.mba
dr.mba's Avatar
Drives: 2017 F. Grey M3 ZCP
I think the sealant may be a bad idea, I am pretty sure it can/will damage your TPMS sensor. You might wanna check that out before using it.
MBA
      05-04-2011, 07:27 PM   #11
dpwr
Drives: a good one
hey what kinda air compressor and a plug kit do you have ?
      05-04-2011, 10:01 PM   #12
1HOT BMR
1HOT BMR's Avatar
Compressor:
http://www.amazon.com/gp/product/B001D5HP40
It's terrific, it inflates a big tire in no time. You don't want to use your cigarrette lighter because it will burn the fuse. Use this instead and connect directly to the battery in the trunk:
http://www.amazon.com/gp/product/B00065L2D8
This is the plug kit that I have never used and hopefully never will. I have no idea if it is any good but it doesn't look too cheaply made:
http://www.amazon.com/gp/product/B000IHK02I
      05-05-2011, 05:38 AM   #13
bobblehead
bobblehead's Avatar
Drives: warp speed
For the Cdn model, F10 uses indirect tpms sensor located in the ABS system. Unlike the US, it uses direct tpms sensor which is located inside the wheel.
MBA
      06-17-2011, 09:50 AM   #14
bongo77
Drives: F11 520d Touring
Useful advice there.
I'm sure the wheels (with tyres fitted) will have a similar overall diameter, so rotation speed will be the same.
My 17" and 20" certainly do- otherwise the speedo would be wrong.
      06-17-2011, 10:55 AM   #15
rightnow
Drives: E92 335d 2010 - Imola Red
LOL, what kind of stupid comment is this?! What other car would be more suitable for long trips than a brand new BMW F10? This goes to my hall of fame.
3000 miles = 4 828.032 kilometers. I've done those kind of trips with my 3-series E92 3 times without no spare wheel. There are tires shops all over Europe here. Its not that big of a problem.
Drive safe!
