2010 2011 BMW 5 Series Forum F10 32hp & 60 ft/lb torque on intake alone? |
03-20-2016, 09:57 PM | #1 |
Rep 9
Hi All,
Saw this on Turner Motorsport Website, https://www.turnermotorsport.com/p-3...intake/?pdk=Ag This sounds too good to be true even for a sealed unit...Any thoughts? |
03-21-2016, 12:10 AM | #2 |
USAF Pararescue Veteran
332
Rep 770
Anyone who claims 32 HP from an intake is a BS artist, period. Any intake is good for maybe 5 HP realistically. That particular company aFe has a history of BS claims. Back when I got my first E60 they were claiming big gains from those intakes, and several dyno runs proved their intakes actually suffered from horrendous heat soak and actually LOST 10 HP in the E60. Seriously, hundreds of people returned their intakes to shops I knew for refunds.
03-21-2016, 08:00 PM | #4 |
Rep 244
Perhaps looking in the right forum and using the search function might turn something up.
http://f10.5post.com/forums/showthread.php?t=987089 http://f10.5post.com/forums/showthread.php?t=1201626
Mike
'04 330i ZHP '11 535i |
03-21-2016, 10:10 PM | #5 |
Dream crusher
984
Rep 2,421
The gains could actually be there if you specially tuned for that setup. Even if it was tuned to that hardware I think you're talking about top end when CFM would be at its highest. Even in that scenario you still need to scoop the air in for maximum pressure.
IG: @bmwdoubles |
03-22-2016, 08:34 AM | #7 |
Rep 1,161
i commented on another post about this afe intake.
they are not claiming a gain of 32 hp on the peak power output, but if you look at the dyno graphs it shows an increase of 32 hp over stock lower down the range / band. so where say the stock intake will be giving 200 hp and 4,000 rpm - the afe will give you 232 hp at 4,000 rpm (i just made the figures up but you know what i mean?) so not a peak output increase of 32 hp over stock, but an increase over stock in comparison.
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
03-22-2016, 09:35 AM | #8 |
Rep 14,521
are people just better off getting a K&N drop in filter instead with somewhat gains or does this fall into hype?
03-22-2016, 11:15 AM | #9 | |
Rep 80
Drives: 2019 BMW X7 xDrive50i
I went with the Burger intake because it looks better (IMO) and cost less, and I knew I wouldn't get any significant power gains. All I wanted was for my F10 to breathe and sound a little better.
http://afepower.com/catalog/54-82082...082-1H1600.jpg
2019 BMW x7 xDrive50i in Phytonic Blue on Black -- 22" 756 Wheels 2015 BMW x5 xDrive35i in Mineral White on Canberra Beige - (sold) 2013 BMW 535i M Sport in Titanium Silver on Black - (sold) 1999 BMW z3 2.3 in Space Gray on Black - (sold) |
03-22-2016, 11:45 AM | #10 | |
Rep 1,161
purely on lower price point and it does look good in the engine bay with it being open. plus in the UK it never really gets above 20 degrees C if you're lucky so heat soak etc, shouldnt be an issue compared to say running it in hotter ambient temps of other parts of the world.
2014 M5
03-23-2016, 02:44 PM | #12 |
Rep 244
Reference the first thread I linked, above. I did before and after dynos going from a K&N drop in filter to the AFE intake. Contrary to El Jeffe's assertions, there is an improvement. Just not 32hp or 60ftlbs anywhere in my dyno curve.
Mike
03-23-2016, 04:54 PM | #13 |
332
Rep 770
One trick aFe has used in the past is running the stock setup on the dyno with no fan in front of the car, then rerunning the dyno run with the aFe intake and a fan blowing DIRECTLY on the intake. Hmm, wonder why it made power?
Also, posting a dyno "showing" gains of 32 hp on your website is effectively claiming your intake provides 32 hp gains. Which is disingenuous at the least. If they reach the claimed numbers via a tune, then that must be stated with the dyno graph, as any legitimate company would. I would get the BMS intake as well, not so much because of expected power gains, but the sound of the engine breathing would be nice. As with all tuning parts, it will not be one part that gets big gains - rather it would be the sum of the parts (intake, exhaust, turbo, fuel, down pipe, charge pipe) + a tune designed to optimize the performance of the upgrades that will make the best power. |
