01-20-2016, 10:19 PM | #1 |
Rep 1,684
I drove my buddies new 535i and it's really impressive. It has the paddles on the steering rig.
BMW did something to the tranny that is so cool: As you step through the gears while giving gas, the car almost chirps the wheels. There is a slight "bang" that simulates a clutch being released. Whatever BMW did, it simply adds to the manual shift experience. |
01-21-2016, 07:19 AM | #3 | |
Rep 140
01-21-2016, 07:30 AM | #4 |
Rep 2,194
In Sport or Sport+ mode, the car definitely shifts harder, I wouldn't describe it as a "bang", or even close to abrupt clutch disengagement. I will agree that the 535i is a blast to drive though.
Bake
01-21-2016, 07:42 AM | #5 |
Rep 1,472
My friend's 335 does this in sport /sport+ mode when using paddles. Not quite sure I'd describe it as "more manual feel"' though.
It does take some getting used to, it's fairly noticeable as you shift. |
01-21-2016, 07:52 AM | #6 | |
Rep 1,684
01-21-2016, 08:03 AM | #7 | |
Rep 1,684
Prior to that lurch, there is a slight negative-g deceleration followed by an enormous power boost. That's what I call the "bang." No, no it's not a clunk type of bang. It's a "omg, am I over stressing this tranny" kind of bang. Somehow, BMW has simulated that little lurch described above. You have to drive it to understand it in manual mode. I also say it's a bang because BMW automatic transmissions are usually so smooth and fluid. This simulation is not your typical smooth and fluid tranny. The 535i in manual mode is brilliant. |
01-21-2016, 09:26 AM | #8 |
Rep 968
I WAS GOING TO TYPE SOME DRIBBLE ABOUT THE NEW 8 SPEED DOUBLE CLUTCH TRANSMISSION
BUT I FOUND THIS INTRESTING READ Automatic transmission. Intelligent technology meets dynamic power: the electronically controlled automatic transmission system enables a sporting, dynamic driving style – without a clutch pedal. It makes driving less demanding and adapts to suit your individual driving style. Instead of a mechanical connection between the lever and the engine a serial bus system is used to convey information about the change. This saves space and weight and minimises engine noise, as without a mechanical connection vibrations are not felt in the vehicle's interior. Stress factors are minimised and the journey is more comfortable. The electronic gearshift control ensures that gear changes are executed without any loss of tractive force, adapting the timing of the shift to suit the current driving situation. The intelligent electronic system takes into account the driving style, whether it's winter or summer, whether a trailer is being towed or whether the road is at sea level or in the mountains. It also notes the speed and position of the accelerator. If the driver presses the pedal past a perceptible resistance a kick-down switch automatically changes to the gear that allows the most optimal acceleration. The precise adjustment of the gear change processes enables a unique combination of sporty and dynamic driving and low consumption. The optional BMW 8-speed automatic transmission sets standards in dynamics and efficiency and is a central component in the BMW EfficientDynamics measures. The particularly smooth gradations of the gears allow optimal power development – from low to high speeds. This markedly reduces fuel consumption while further increasing sportiness and dynamics. The extra gears reduce the number of revolutions at high speed and thus the consumption and engine noise. The system is supported by the newly-developed and more efficient converter clutch – even if you use the electronic gearshift lever to change gear manually. Combined with precise shifts and low rev intervals between changes, the transmission ensures extremely comfortable gear changes and markedly reduced background noise. The BMW 8-speed automatic transmission is the first automatic transmission available with Auto Start Stop function. This doesn't just save fuel when driving, but also at every traffic light. Sporty ambitions? Experience maximum dynamics, efficiency and driving comfort with the optional 8-speed Sport automatic transmission: its short shift times improve acceleration and aid sporty driving. The gentle gradation of the eight gears reduces the engine's rev interval between shifts, so the transmission process is barely noticeable. At the same time, the engine is always held at the rev level at which it can optimally utilise its strength – increasing dynamics and efficiency and reducing the noise level. The eighth gear reduces the number of revolutions at high speeds, tangibly increasing comfort while reducing fuel consumption and emissions. The double-clutch transmission of the 7-speed Sport automatic and the M DKG stand for extraordinary sportiness and dynamic driving pleasure. Composed of two interlocking, mechanical parts, it shifts to the next gear while the previous one is still active. The gear change is thus completely without interruptions. With the Steptronic, drivers that want to take hold of the reins can transform any BMW automatic transmission to a 'manual' one with press of a button. Depending on the model, the driver can then change gears manually using the gear lever or the shift paddles on the steering wheel. For unrivalled driving pleasure – right down to your fingertips. |
01-21-2016, 09:30 AM | #9 | |
Rep 1,472
It's even more brilliant with actual manual transmission, RWD and DHP . (Not really serious, although it's what I personally prefer, just having some fun and attempting to "brag" a bit ) |
01-21-2016, 11:48 AM | #10 |
Rep 1,873
Possibly worth noting that there are many different shift programs available. I don't have any DHP modes in my 11 535, just a DS mode for the transmission. Now that I have an M Perf exhaust I can hear different modes of operation more clearly. There are lazy smooth shifts, there are shifts that sound exactly like I'm driving stick (reduction in sound and power, shift, power back on), and then there are shifts with no power gap, a lurch forward and a brappp from the exhaust. More like I had sequential shift. The last shift type really only happens when you're into boost and at least moderate revs when you ask for the shift
Maybe you're feeling the braapppp shift that you like the feel and sound of |
01-21-2016, 02:49 PM | #11 |
Rep 74
Per the above read you guys may have some problem-
"Experience maximum dynamics, efficiency and driving comfort with the optional 8-speed Sport automatic transmission: its short shift times improve acceleration and aid sporty driving. The gentle gradation of the eight gears reduces the engine's rev interval between shifts, so the transmission process is barely noticeable."
This is from the above post quoting the BMW dribble. And, it is how mine shifts, you can hammer it and still shift through the gears with a smooth transition from one to another. Perhaps some of you need to reset your transmission or have them looked at or reprogrammed next time you are in the shop. |
01-21-2016, 03:08 PM | #12 | |
Rep 1,873
No resets change the three shift types: buttery, like stick, and brrapppp. Prior to the performance exhaust I couldn't hear the brap. |
01-25-2016, 05:47 AM | #14 | |
Rep 1,873
my theory is it is simply a shift mode (not to be confused with a "driving mode" like DS or sport) that's used sometimes. There's a couple of basic components to an AT shift - the hydraulic shift pressure/speed and how the engine power cutback is performed. It's my thought that the brap shift is retarding the timing but not cutting spark or fuel in order to keep the boost maximized during the shift. The other two types may interrupt fuel and/or spark. I've sought technical details before but never found any so I'm left to my educated guesses. |
01-25-2016, 09:40 AM | #15 | ||
Rep 1,684
The feeling that I am trying to convey is that slight negative G that you feel when shifting a true manual while attenuating the throttle as you shift. BMW could simulate that negative G by tapping the brakes as you shift from Mx to My at speed. I noticed this simulation only takes place after the engine is warmed up. |
01-25-2016, 03:36 PM | #16 | |||
Rep 1,873
10-20-2020, 01:06 PM | #17 |
Rep 5
Need help
So, i am new to bmws and stuff, and i got a 2015 535i, and when i put it into sport and manual when i go to shift the car shifts itself, like what should i do that stop that?
