2010 2011 BMW 5 Series Forum F10 HELP! CAn eBay EVC wiring FOR work Meisterschaft? |
03-24-2016, 09:03 PM | #1 |
Rep 14,522
More like I got it used with no remotes or anything which is fine and the valves are set to be open all the time which is how I was gonna run it. looking at what looks like a motor or actuator is this controlled with voltage if im saying that right? I was wondering if there's a way for me to run some wires from those actuators to maybe a button or switch inside that can open and close the valves?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 03-26-2016 at 07:49 PM.. |
03-25-2016, 06:43 AM | #2 |
Field Marshal 🔱
144
Rep 294
Drives: 2019 M5 Competition (F90)
You would need to know what voltage and current are required to activate the actuator. I would think that there would be a need for a control module and not just wiring straight from a switch to he actuator. It could be easy enough to test with a battery before the installation.
2019 F90 M5 Competition - Black Sapphire Metallic
2015 F10 535i xDrive M-Sport - Jet Black (retired) 2008 E60 528i - Space Grey (retired) 2002 E46 325i - Space Grey (retired) 1999 E46 328i - Orient Blue (retired) |
03-25-2016, 08:06 AM | #3 |
Rep 14,522
I'll see what it sounds like when it's installed and go from there. From all the YouTube videos it sounds incredible but would be nice to have the ability to close the valves if I want to tone it down a bit.
03-26-2016, 07:32 PM | #4 |
Rep 14,522
03-26-2016, 07:57 PM | #5 |
Rep 5,337
03-26-2016, 08:11 PM | #6 |
Rep 14,522
Well that's the one off the Meisterschaft. I wanna replace it with a new one and was wondering if the eBay one's will work?
03-26-2016, 09:24 PM | #7 |
Rep 862
You definitely want to be able to close the valves. Cold starts are really loud with the valves open. I just can't do that to my neighbors during off hours.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
03-26-2016, 09:37 PM | #8 |
Rep 14,522
That's what got me thinking lol! I'm looking at the Meisterschaft actuator or solenoid or whatever it's called and it does have 2 wires coming off of it...one red and one black. I should be able to hook up a switch inside with a fuse and be able to open and close wouldn't you think?
03-26-2016, 10:22 PM | #9 |
98
Rep 305
Im not sure what the genuine one uses, but the ones on ebay are just generic replacement motors for exhaust cutout kits.
Just stick to one that uses actual connections(stay away from bluetooth version, dont ask me how I know) if you find out that those will work with the exhaust you picked up. Measure the diameter you need and go from there, SHOULD be pretty straightforward. |
03-26-2016, 10:55 PM | #10 | |
Rep 14,522
03-26-2016, 11:37 PM | #11 | |
Rep 5,337
As long as that's all that valve does. |
03-26-2016, 11:55 PM | #12 |
Rep 14,522
That's all it does...opens and closes
03-27-2016, 02:15 AM | #13 |
Rep 947
My father was an A Grade Mechanic in his younger years and he taught me a lot about Motors but he knew diddly-squat about Auto Electrics. Having said that, I'd be mindful where you run your wires as it will depend how many amps those actuators need as they might cause issues with voltage irregularity if they draw too much and at the wrong time (particularly at ignition start-up). Just looking at them though, doesn't look like they would be more than 3-5 amps each but I'm certain some of the boys on this forum will have more idea. You might need to run a 15 Amp relay just to be on the safe side. Just a thought but why not reach out to the guys at Meister as they know their own product and I'm sure they wouldn't mind giving some free advice.
Current Mistress: 2014 F10 535D M Sport - Alpine White
Retired but not forgotten: 2011 F10 535i - Titan Silver; E53 X5 4.4L Sport - Space Grey; E46 M3 Individual Convertible - Phoenix Yellow; E39 528 - Glacier Green; E36 328 Convertible - Montreal Blue |
03-27-2016, 11:33 AM | #14 |
Rep 14,522
Thanks Craig! Ill send them an email!
03-27-2016, 02:52 PM | #15 | |
98
Rep 305
