2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 523i low pressure help
      06-09-2019, 06:35 AM   #1
beastlysun
Drives: BMW F10 523i 2011
Unhappy F10 523i low pressure help
Hello all
Recently my car (F10 523i 2011) is a bit sick and needs a lot of antention. The BIG issue is low pressure in high pressure rail. Under 140bar to be exact.
It is N53B30A engine and i know about issues with HPFP, but i realy hope it is not the case for me. Mostly when i search around there are much more severe issues than my car developed
Here are some points from last 1-2 months
-car starts OK when cold, but occasionally i get a little bit longer crank time (less tha 2sec) when engine gets hotter (70 celsius and above)
-no problem when engine is cold
-no problem in sport mode (pressure still drops realy low, but no error
-idle is a tiny bit shaky, but rev stands still without drops
-hpfp pressure test OK and holds pressure without any issues
-checked all injectors, one was dead (leak) other were cleaned and tested OK
-can accelerate with cruise control without issues
-if i dont accelerate too much (stay bellow 25% throttle, or accelerate in short taps) no errors
situation when error occurs:
-oil temp above 90
-transmision in normal mode
-press and hold accelerator above ~25% for more than 10-15sec
after drivetrain error pops up:
-cooling spools upt to 100% cooling down the engine deeply below 90 degrees celsius
-LPFP goes to 100% PWM
-slight increase in consumption
-ride quality unchanged (acceleration is as before)
Last resort for me is HPFP. At least from my (small) knowledge. Any help would be realy helpfull
      06-15-2020, 04:52 AM   #2
HotSpicyChicken90
Drives: BMW 535i
Do you have ISTA?
      06-15-2020, 05:02 AM   #3
beastlysun
Yes, this was sorted when that HPFP refused to go any further and had to be replaced. Issues gone from that time
