2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 retrofit rear electric sunshade
      11-27-2019, 04:44 AM   #1
uas66
Drives: 528xi
Hi all,
I am planning to retrofit my car with electric rear sunshade. I have a couple of questions, hope you could help me.
I searched on the internet and found out that I need to replace the rear shelf with the motor. Also I need to replace the swich on the drivers side door panel with the shade button.
  • The sunshade has 2 wires to the motor. Where do I connect the 2 wires from the motor to? To the switch or some module?
  • Do I need to code something after installing it, or will it work without coding?
  • Are there any fuses that I need to install?
Thanks in advance!
      11-30-2019, 01:31 PM   #2
addy27
Drives: F10 550i
Check up on Newtis.info for wiring diagrams. That should give you all that you need
      12-02-2019, 02:55 AM   #3
uas66
Drives: 528xi
Yes I looked on Newtis. I found out the wiring diagram.
I need to add 2 pins to the JBE, connector A34*1B, pin 3 and 30. My question is if I can use my own JBE or do I also need to replace this module? My JBE number: 61359286941-03.
      12-02-2019, 06:42 PM   #4
addy27
Drives: F10 550i
Pretty sure you should be able to use your JBE just might need to code it using ESYS.
      12-03-2019, 02:30 AM   #5
uas66
Drives: 528xi
The strange thing is that I can not find my JBE (61359286941) on the listing here:
http://bmwfans.info/parts-catalog/F1...c_3/#9267455_1
So I am not sure if the JBE is compatible with S415A (Sun-blind, rear.)
      03-23-2020, 07:05 PM   #6
Vale70
Drives: Bmw serie 5 f10
Hello!! Were you able to finally complete the brico ? I have found an electric curtain and would like to do it. I think my tray would serve me I would only have to trim the hole for the curtain that I do not know if it comes premarked behind the tray itself. A greeting
      04-05-2020, 04:29 AM   #7
RJV3
Customize Everything!
Drives: 17 F06 Gran Coupe/ 16 F10 535
Definitely interested in seeing the final product. How much were all the parts and where did you pick them up from?
      04-08-2020, 07:41 PM   #8
addy27
Drives: F10 550i
Was this completed? OP any feedback on where you connected?
      04-09-2020, 04:47 AM   #9
uas66
Drives: 528xi
No, not completed yet. I am not sure if the JBE module is compatible with S415A (Sun-blind, rear). So if also the JBE needs to be replaced I think it is not worth retrofitting.
Tags
electric, f10, rear sunshade, retrofit
