06-16-2020, 08:00 AM | #1 |
Rep 29
2013 f10! Noise
Hey what's sup guys I am new too the f10 world I just picked up one with 107k mikes. Everything seems to be cool until I accelerate at high rpm and it starts too like a whistle or whine noise only if your window is open
06-16-2020, 09:57 AM | #3 |
Rep 29
06-16-2020, 01:38 PM | #4 |
Rep 915
Does it get louder with rpm? I had my transmission make a whining sound ended up being 1 qt or so low fluid. Soon as I topped it off it went away. More or less sounded supercharged imo. Turbos make a whine also when the bearings are failing internally.
Instgram @burninja
06-16-2020, 01:41 PM | #5 | |
Rep 29
BurrNinja430.50 |
06-16-2020, 04:07 PM | #8 |
Rep 915
See if you can get someone to record a sound clip or something. No engine lights? Have you had a diagnosis check with ista? Does your car feel powerless, shift lagging? Does it happen all the time. Have gotten paperwork on any work done to the car. Do you any fluid leaks. Many questions man. Id try to check out your car to see if you notice anything in bay loose hoses, fluid leaks and under car.
Instgram @burninja
06-16-2020, 04:12 PM | #9 | |
Rep 29
BurrNinja430.50 |
06-16-2020, 04:30 PM | #10 |
Rep 63
Drives: 2012 BMW 535xi
06-16-2020, 04:46 PM | #11 | |
Rep 29
06-16-2020, 04:47 PM | #12 |
Rep 915
This can be too! If you hear a squealing even at idle could be rear main seal/front main seal. One test to see when you hear the noise open hood at idle and pull oil filler cap off if the squeal goes away or rpm's stumble like the engine is going to die then you have bad pcv. Normally under load you will not hear it though, its usually when letting off the throttle air gets sucked in.
06-16-2020, 04:58 PM | #14 |
Rep 29
Just noticed it like it would make a wind sound hard to explain but it's as soon as I press the gas it makes that noise but when I let go of the gas it doesn't make that noise
06-16-2020, 07:01 PM | #15 | |
Rep 1,261
06-16-2020, 07:49 PM | #16 |
Rep 915
There has been transfercase failures, could be any rotating assembly that is under load failing or lack of proper lubrication.
Instgram @burninja
OnlyGerman363.50 Bmwahova3.00 |
06-16-2020, 10:32 PM | #18 |
Rep 29
06-17-2020, 08:48 AM | #19 |
Rep 659
Just wondering if it is the turbo you are hearing.
Trainwreck914132.00 |
