2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums USA - NY/NJ/PA/CT front passenger wheel temperature
      07-05-2020, 10:10 AM   #1
joleonie
Drives: 535xi
The wheel temperature on the front passenger side goes up 10 degrees higher than the rest of the wheels. The last drive I did was for 1.5 hrs on the highway and the temp just rose to 10 degrees while the rest of the wheels remain almost the same. I got no clue why. New wheel hub on this wheel but was alredy doing the crazy temp rise before. Anybody had this same experience with rising temp?
535i xdrive 2016
78,000 mi
      07-05-2020, 11:26 PM   #2
1margarette
1margarette's Avatar
Drives: 2014 BMW X1
It sounds as if the right front brake caliper piston failed to properly retract or binding of the caliper's sliding pins caused continuing clamping of the brake pads. Also, a faulty wheel bearing can generate considerable heat, but would have additional identifiable symptoms such as looseness or noise
      07-06-2020, 08:13 AM   #3
NYC535iowner
Drives: 2013 535i X-drive
I noticed the same after changing my front driver side wheel to a NON runflat tire. The temp is always higher on the non-runflat tire.
the front passenger tire (Runflat) will be at 98F and the driverside tire (non-runflat) will be at 106F.
13'- F10--> Work in progress: V-Style front lip, HAMANN roof spoiler, M5 grill, high kick trunk spoiler, H&R sport springs, C-quence Drilled front rotors, VRSF Catless DP, VRSF charge pipe.
