2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Retrofitting Brand New NBT EVO Unit? Is it possible?
      08-25-2022, 08:25 PM   #1
SocomCA
Drives: BMW M6
Hey,
Does anyone know if you can buy a brand new nbt evo unit from bmw and a new atm module and make it work in a f10 so it has connected drive services?
Or does the atm module and nbt evo unit need to be used?
The problem i see is that the vin number will be the same for the atm module so bmw might not provision it versus having a used atm module that is already provisioned.
      08-25-2022, 11:24 PM   #2
Originally Posted by SocomCA View Post
Hey,
Won't work economically. A BMW specialist here has tried and said the parts alone are roughly $2000... PLUS installation; IF you can find someone to do it. I just gave up and bought a G30.
      08-26-2022, 01:10 AM   #3
SocomCA
Drives: BMW M6
You dont think a dealership can do it?
      08-26-2022, 12:53 PM   #4
Originally Posted by SreeM View Post
You don't think a dealership can do it?
it isn't if they can, it's if they will. I don't know all the parts required as I didn't ask. I do know it's at least new HU & wiring harnesses. There are also possible compatibility issues with the other systems. I don't know if he ever got 4G to work.
      08-27-2022, 12:23 AM   #5
KillFox91
KillFox91's Avatar
83
Drives: 2014 BMW X35i
I have a used atm, atm wiring harness, and emulator if you want to go down the rabbit hole
      08-27-2022, 02:12 PM   #6
ceka
ceka's Avatar
24
Drives: 530d 11'
Here's a few links, lots of info..
I'm trying to get Bimmertech to sell this service without the screen because I want to source/install the g01 touchscreen instead of the f10 non-touch that's tucked inside.. And I already have a iDrive Touch Controller.
Not cheap anyways
https://www.bimmer-tech.net/category...ystem-retrofit
https://f10.5post.com/forums/showthread.php?t=1570125
https://f10.m5post.com/forums/showthread.php?t=1838265
Tags
atm, nbt evo, retrofit
