2010 2011 BMW 5 Series Forum F10 Installing P3 Boost gauge on 550.... |
09-30-2013, 09:23 AM | #1 |
Rep 8,809
Has anyone installed one of these gauges on a 550 yet? Wondering how involved the install is for this car in terms of where you are tapping for boost pressure. I am pretty technical but simply don't have the time to spend hours wrenching on the car nowadays.
Alan
09-30-2013, 09:32 AM | #2 | |
Rep 966
You will need an adaptor if you want to add the mechanical gauge - Dinan sells one for something like $80, haven't seen them anywhere else. |
09-30-2013, 09:41 AM | #3 |
Rep 8,809
Yeah i just saw the diy video and looks super simple.
I am wondering for those of us with the JB tune where it tricks the ECU to make more boost will the obdII signal show actual boost or what it thinks its only making? Guys with this boost gauge and JB tune please chime in. Not interested in installing a manual gauge on this car. Alan
09-30-2013, 10:21 AM | #4 | |
Rep 966
09-30-2013, 10:54 AM | #5 |
Rep 8,809
You are right. Terry just replied on another thread that the boost reading from the obdII port won't be accurate with the JB so it is pointless for me to get it.
09-30-2013, 12:43 PM | #6 |
Rep 966
I don't know if I would buy it without an accurate boost reading either, but it does have some other cool functions that should still work for you - EGT, IAT, timing, coolant temp, battery voltage, road speed, RPM, shift light, 0-60 timer...
10-01-2013, 01:36 PM | #7 |
Rep 2,080
+1... same for e9x JB platform. You need to tap physical boost, but not sure where that is on N63/N63Tu.
10-02-2013, 10:08 AM | #9 | |
Rep 2,080
On the E9x platform, when running Jb3/Jb4 which taps the ecu directly, you can read boost via OBD. However, with the JB+ for N54 and Jb Stage 1 for N63, it's intercepting the actual boost sensor so the ECU should see true boost. Anyone with a BAVTECH cable running the N63 tune can confirm. If I can find mine I'll do so. |
10-02-2013, 10:29 AM | #10 | |
Rep 966
These numbers are probably not accurate, but will work for explanation: Imagine if the MAP sensor sends a range of 0-5V to the ECU representing boost where 3V = 10psi. The tune is reading that value then adjusting it to say 2V so the ECU asks for more boost. Now when the ECU sees 3V, it is actually 14psi but it will think it's only 10psi which will show in the logging/gauges. |
10-02-2013, 11:23 AM | #11 |
Rep 232
i just hook my cable to my laptop and log my boost. Thats the only real way to get true value
but ive been trying to install my aem gauge but no source of boost.
2015 BLK/BLK X5 35i - M sport
997.1 GT3 |
10-02-2013, 11:48 AM | #12 | |
powerhouse
708
Rep 1,628
Drives: 2014 Porsche 981 CS
i haven't looked at it since i coded my car and i've been thinking about how you do that lately.
no signature. except for this one.
10-02-2013, 11:58 AM | #13 | |
Rep 966
You need one of these for your AEM gauge: http://www.dinancars.com/products/5-...apter-Kit.aspx |
10-02-2013, 02:14 PM | #14 |
Rep 514
I installed a P3 gauge the other day in my car. It was super easy and took me less than 5minutes. At the time, I had the BMS tune installed which showed I was boosting 12.5psi. When I removed the BMS tune, I was boosting 10.2PSI. BMS adds 2.25psi so if the gauge is setup to round up,which mine is, it works perfectly.
10-02-2013, 03:48 PM | #15 |
Rep 8,809
Strange.... because Terry on his own forum keeps saying that boost reading won't be accurate with this gauge and the JB on the N63......
Alan
10-02-2013, 07:06 PM | #16 | |
Rep 514
"The gauge defaults with sensor locations for a n55 engine car. Please enter config and change to n63 . The n63 map sensor only reads to 3 psi... So the gauge had to read the charge pipe sensor as well." I wonder if reading the charge pipe sensor as well as the map sensor has something to do with it on the N63 engine? |
10-02-2013, 08:34 PM | #17 |
Rep 63
Interesting. When I plugged my ScanGauge II into my 550ix, I only saw ~17 PSI MAX for MAP absolute pressure, but this includes atmospheric, so I would need to back that out and get about 3 PSI net. I was hoping that wasn't right, lol. I wanted to get a P3 gauge, but wanted to make sure it would work correctly, so I emailed the P3 guys and they assured me it would work and said didn't rely on the MAP sensor alone.
In the Bavarian Tech software, you log the atmospheric pressure and the Intake charge pressure 1 and 2 for boost in each manifold. The atmospheric pressure changes slightly, but not as much as the MAP sensor readings I would see when watching my ScanGague II. You have to calc the boost by subtracting the atmospheric pressure from the charge pressure and multiplying by a constant (values are in hPA). Strangely, I don't recall seeing the MAP absolute pressure reading as an option to log in the Bavarian Tech software. Anyway, if the JB tune modifies the intake charge pressure readings, it does seem like it wouldn't work (since the calc would be wrong). If JB changes the MAP sensor reading, the P3 gauge could calc correctly since the MAP absolute pressure isn't part of the eqn to calc boost. However, it is also strange that Terry himself said the P3 gauge wouldn't work? |
