2010 2011 BMW 5 Series Forum F10 Jb4 installed this weekend, wiring questions |
04-10-2017, 10:29 AM | #1 |
Rep 81
I installed my jb4 this weekend and was unable to route the wire in a clean way like the install shows due to the wire lengths being so short. Instead I had to run the wires inbetween the rubber and plastic cover opening. What did I do wrong? Also I have a manual transmission so I didn't really install obd II. Any advice on installing this?
04-10-2017, 12:14 PM | #2 |
Rep 62
It's definitely a very tight fit. You have to get creative with how you route the wires to make the distance as short as possible. Here are links to the only pics I currently have of it installed, hope they help.
https://drive.google.com/open?id=0B8...kFLczYxbHI0cXM https://drive.google.com/open?id=0B8...3M4SjJ0bG05Wk0 https://drive.google.com/open?id=0B8...UM1V1MxbVpDazA |
04-10-2017, 12:23 PM | #3 | |
Rep 81
04-10-2017, 12:28 PM | #4 | |
Rep 62
04-10-2017, 12:39 PM | #5 |
Motiphd
122
Rep 232
OP, how does it drive in your opinion?
2016 535i xDrive M-Sport | 2016 328 xDrive w/Lighting (hers)
2012 VW Jetta GLI 6MT APR Stage 2 (retired) | 2012 VW Tiguan SEL 4Motion (hers/retired) 2012 Acura TL SH-AWD Advance (retired) | 2012 Acura RDX Tech (hers/retired) 2010 Acura MDX SH-AWD Advance (hers/retired) |
04-30-2017, 08:39 PM | #6 |
Rep 41
Drives: 2011 535i 6MT & 2015 M6 GC CP
Let me know if you still need help with this or pics. I just did mine this weekend. I ran the wires under the intake since I had pulled a lot of that off to replace spark plugs. I ran the OBDII wire through the firewall in the area in front of the driver. I think the hole in the firewall is for the hood latch and has a rubber grommet. I pushed the rubber grommet in towards the interior cabin a bit and ran the wire beside. I then taped (black duct tape) around the wiring where it runs thhrough the firewall to protect it from chafing on the metals since I couldn't fit it through the rubber grommet.
Again, let me know if you need pictures. |
04-30-2017, 09:59 PM | #7 | |
Rep 81
05-01-2017, 08:02 AM | #8 |
Rep 194
I asked the same question this weekend regarding the OBDII connection. Very prompt and helpful response!
"The OBD cable would be recommended regardless of whether you're using the Bluetooth kit, they do not provide the same functions. Not connecting the OBD cable limits the JB4 to map 1 performance regardless of the performance map selected, and datalogging will be limited to boost information. In addition, some features will not work at all like the in-dash boost gauge, code reading and clearing via the JB4 app or interface software, and other CAN-related features. Best, Jon BMS" |
05-01-2017, 08:03 AM | #9 |
Rep 41
