2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Racing with RWD 550i
      08-17-2015, 10:33 AM   #1
Zer0Cool92
Drives: blue metallic
What's the best tips to race from a dig with a 550i RWD?
Stability control on ? Or traction control completely off ? What rpms to launch? Optimum RPM to shift?
From a roll, say 20mph.. 2nd gear? What RPM to floor it in 2nd?
      08-17-2015, 11:21 AM   #2
ArchJR
Drives: 2024 i4 xDrive40
Have you tried using the launch control?
_______________________________
current: G20 330i
retired: G30 540i, F10 528i, F30 328i
      08-17-2015, 12:06 PM   #3
Zer0Cool92
I've got a 2011 550i non m sport so I don't think it has launch control
      08-18-2015, 07:40 PM   #4
Zer0Cool92
Ttt
      08-18-2015, 09:02 PM   #5
dblock2151
Drives: '11 550i Msport DG
I usually keep it in "Sport" setting, keep the transmission in "DS" and just gun it. Try braking and launching at different RPMS, but Badblack on the forums would be the best person to speak too as he does the 1/4 mile the most on here.
      08-19-2015, 04:21 AM   #6
Zer0Cool92
Ya he's got AWD tho.. He can prob launch at 3k rpm with his car. I think he has sport package so he's got launch control.
      08-19-2015, 07:24 AM   #7
Gpfarrell
Drives: 6MT Imperial Blue 550i M-sport
Stick or auto?
      08-19-2015, 07:43 AM   #8
Zer0Cool92
Originally Posted by Gpfarrell
Stick or auto?
Auto.. Is it best to take traction control completely off by holding on dsc button or just pushing the button. Because keeping stability control says it keeps maximum traction
      08-20-2015, 08:35 PM   #9
Zer0Cool92
Ttt
      08-21-2015, 06:49 PM   #10
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
For me I usually have it in sport+ and the shifter in ds mode and brake boost at around 2500-3000rpm.. pretty good results so far.
      08-22-2015, 08:11 AM   #11
Zer0Cool92
Sport + takes traction control completely off right ?
      08-22-2015, 10:57 AM   #12
Simple5
I believe sport+ limits it but does not turn it completely off. Equivalent of hitting the dtc button once.
      08-22-2015, 04:08 PM   #13
Ben2k9
Drives: 2011 BMW 550i M-Sport
I don't think 2011 msport has launch control. Or if it does, I'd like to hear about it!
      08-24-2015, 09:21 AM   #14
493263
493263's Avatar
71
Drives: 2011 550i xDrive
Yes, Sport+ switch TC to DTC. There's still traction control, but it lets you slip a little. I tried it in a parking lot last winter.
      08-24-2015, 11:11 AM   #15
Gpfarrell
Somewhat generically and universally, it's a weight-transfer game with a rwd car.
My F10 isn't a 550, but my 450hp 4-door Mercury has similar physics.
First, push all of the buttons the right way. Aside from cars with serious Launch Control, most traction controls are designed for additional safety and stability, not acceleration. They cut throttle and/or apply brakes... so its best to defeat them as much as possible.
Second, hold a foot on the brake and build rpm's and boost modestly... with practice you'll learn how much you can get away with before you just lose everything to tire smoke.
When the light turns green... wait, you must be at a drag strip, so when the last lights on Christmas Tree turn yellow... never wait for the green... release the brake and smoothly apply full throttle.
Don't smack the pedal to the floor. Try to immediately, like instantly, get 1/2 throttle and then spend about a second getting the pedal to the metal. 1/2 throttle shouldn't spin the tires, it should move the car pretty hard though. This will allow the weight to transfer onto the back wheels and really plant them... giving you maximum grip to harness all that horsepower that you gradually pour on.
This takes way more concentration than you'd think is necessary but the physics involved in hooking up 400+ hp in under 2-seconds takes a little finess.
      08-29-2015, 10:09 PM   #16
RSBro
RSBro's Avatar
Drives: 2012 550i M-Sport
For me it seems to be in Sport, hold down the TC button to turn if "off", Sport transmission mode.
However as Gpfarrell said, with the RWD 550s getting all that HP to stick off the line (especially on RFTs...) is pretty touch. The xi's do better with it. I've learned to not mash off the line because if you go over little bumps I can feel it break traction and cost a little time.
I also shift at 5k RPM as I've seen on most dynos after that you start down on the power band. Somewhere around there, anyway, so shift at about 4.5k to hit 5k.
The best thing about the F10 is the look on people's faces when your 10,000lb saloon leaves them in the dust. Total sleepers. I love racing off the line with my massager and cooled seats on.
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
      08-30-2015, 01:24 AM   #17
Simple5
Reading the posts on the BMS boards show that the n63 engines take a big hit in power (drop off) at around 5k RPM.. smart to shift at around that point...
      08-31-2015, 08:09 AM   #18
493263
493263's Avatar
71
It's not that simple. It's about torque at the wheels so you have to account for all gear ratios. Just because it's dropping off doesn't mean you should upshift. All you have to do is table/chart of how much torque is applied to the wheels at certain rpm for each gear.
There's no point in manually shifting the auto. The gear ratios of the ZF 8speed are spread pretty close to each other. I doubt you can manually shift faster than letting the autobox do its thing.
      08-31-2015, 08:32 AM   #19
RSBro
RSBro's Avatar
The best drag times (Badblack for instance) have been manually w/ paddles while in 'manual' shift-to-left mode that I've seen. Now that's not to say for most people the auto wouldn't be faster. A lot of times I leave mine in auto and it dispatches most cars with the quickness.
      08-31-2015, 11:31 AM   #20
493263
493263's Avatar
71
Because he's modified the ECU without modifying the TCU.
      09-17-2015, 09:46 AM   #21
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
It's easy in a manual car but since I got the BMW with the steptronic I've yet figured the right way to launch?
      09-17-2015, 11:49 AM   #22
Polo08816
Drives: 2014 335i M Sport
What I've been told to do is roll the car in reverse and then put the drive selector into D as fast as you can. The rolling back motion ensures that you get a nice holeshot. I've been able to beat a lot of cars with that technique.
