2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Painting the silver bumper trim (pre-LCI, non-M-Sport)
      06-18-2018, 03:55 PM   #1
InsertNameHere
Drives: F11 530d xDrive 2012
Hey,
I am thinking about spray painting the silver bumper trims on my F11 and I was wondering, you people who have done it, what paint did you use? Just regular (matte)black spray paint? Or automotive spray paint? How about sanding? Is it required?
TLDR:
- What spray paint?
- Sanding required?
Thanks!
      06-18-2018, 07:57 PM   #2
Originally Posted by InsertNameHere View Post
Hey,
TLDR:
- What spray paint?
- Sanding required?
Thanks!
Prep is everything!!! You'll want a plastic paint or at the very least one with a flex-agent. YouTube is your friend here. I would watch as many as you can stand before starting the job. You'll want to rough-up the surface some to give the paint (primer) something to stick to. I've successfully used Rust-Oleum for plastic. Flat (matte), semi-gloss or glossy is entirely up to your prefrence.
      06-19-2018, 12:44 AM   #3
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
I just bought them pre-painted from IND
https://ind-distribution.com/product?sku=IND-F10-FREF
      06-19-2018, 04:42 AM   #4
InsertNameHere
What does this "flex-agent" mean exactly?
      06-19-2018, 06:40 AM   #5
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Plastic is bendable, steel isn't, so using a flex agent( exactly how it sounds, helps it flex without cracking paint) is what you always want to use with plastic.
      06-22-2018, 11:52 AM   #6
whinojosa
Drives: 2011 535i (6sp)
2011 BMW 535i  [0.00]
It can also be called Adhesion Promoter I believe made by SEM. Check out paintscratch.com, they have some good info on there. Painting the inserts might be a fun, low-risk project to get you started in painting! A lot of these paint vendors will also sell you the base coat of the specific BMW color code so you can do body-matched trim and such.
