2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Error in steering column?
      04-09-2018, 10:26 AM   #1
mposs93
Drives: 2015 f10 5 series
I'm having an issue with my 5 series f10. I have an error that says the touch detection on the steering wheel is missing, but my car doesn't have any touch detection on the steering wheel. Error codes are 30364 and C98402. Any help clearing them would be appreciated.
      12-29-2022, 12:37 AM   #2
arturlu
Drives: F10 520d 2016
Hi, I’ve got similar problem:
I’ve done combination switch retrofit to add High-Beam Assistant in BMW F10 2016 year.
Original part number 9354045 replaced with 9214963. No paddles, no vibrator, not heated steering wheel. VO changed to 2TB (sport+ enabled).
Everything works ok, but I can't eliminate the error:
C98402 Message (steering wheel vibration control, 110.1.2): none, SZL receiver, ICM transmitter -1 Information
Replaced switch encoded by esys with CAFD_0000033D_001_009_002 file.
Vibration off in:
SZL > 3000 > Lenkrad_Vibration > nicht_active
ICM > 3000 > C_ZSW_Lenkradvibration_Spurwechselwarnung_enable > nicht_active What else can cause this error?
Thanks for any suggestions.
Best Regards
