2010 2011 BMW 5 Series Forum F10 Staggered Setup for XDrive? |
09-17-2016, 01:24 AM | #1 |
Rep 4,209
Hey guys,
So the next thing I want to get is rims for my car. I really want to get rid of that wheel gap. My question is that can I run a staggered setup with Xdrive? Also, any recommendations on rims for my car? Thank you! |
09-17-2016, 05:09 AM | #2 |
Rep 5,140
No issues with staggered setups on xDrive cars, just need to match front and rear tire diameters. Two possible tires setups, either 245/285 or 255/295.
Exampel of staggered wheel and tire combos for F10 xDrive: F: 8.5x20" ET25, 245/35-20 R: 10x20" ET40, 285/30-20 F: 9x20" ET30, 255/35-20 R: 10.5x20" ET45, 295/30-20 The wheel offsets can vary a few mm without issues. Wheel diameters can be 19, 20 or 21", but the tire profile needs to be matched for chosen wheel size. |
09-17-2016, 12:37 PM | #3 |
Rep 29,202
Lower the car to get rid of the wheel gap.
09-26-2016, 10:43 PM | #5 |
Rep 749
Drives: 2016 528i Executive Edition
Just wanted to add, if you go bigger wheel while maintaining the proper wheel/tire specs, going up a wheel size will actually appear to increase the wheel gap. It's like an optical mind fu#&.
The only way to get rid of wheel gap is to lower your car lol. |
09-29-2016, 10:30 PM | #6 |
Rep 357
Sorry to hijack but this might be useful to op.
Do any of you with staggered xi have weird noises on your drivetrain? Like when you very lightly step on the gas during cruising? |
10-04-2016, 06:03 AM | #7 |
Rep 372
On my M550d xDrive the wheels that came with the car were:
Fronts: 245/35-20 Rears: 275/30-20 The rears are actually slightly smaller by some mm. |
10-18-2016, 12:28 PM | #8 |
Rep 2
Sorry for posting to this thread, but cant make a new one.
So I drive an F10 530d XDrive and it has OEM style 351 wheels, which are staggered. Theyre 8.5 front and 9 rear. At the moment Im using tires 245/40/19 and 275/35/19, but winter is coming and I want to use spiked tires, sadly manufacturers doesent produce spiked tires in this size or they are really hard to get. Since I have xDrive I cant just put any other size tires on them because of the circumference difference which will start damaging the transmission. I used a tire calc and got a 0% difference with tires 225/45 and 255/40, the difference of radius is 0.2 inch. On paper it should work, but Im not an expert and still hesitating, dont want to ruin the transmission. What do You guys think? Am I okay with this setup? I dont mind the stretched tires, main thing is that I can drive without damaging anything. |
10-18-2016, 01:16 PM | #9 |
Rep 5,140
Those sizes will be fine with xDrive.
F30 M Sport with xDrive has 225/45 front and 255/40 rear from factory, but with 18" wheels. Since you don't mind the stretched tires, I don't see any other issues either. |
10-18-2016, 02:46 PM | #10 |
Rep 29,202
I'd just go 245/40/19 all around.
I've done that myself, studless tires though and no xDrive.
12-08-2016, 03:14 AM | #11 | |
24FITcoach
32
Rep 76
http://f10.5post.com/forums/showpost...75&postcount=5 |
09-12-2019, 09:54 PM | #12 | |
Rep 439
Drives: 2016 M235i Xdrive 8A
Thanks
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
09-16-2019, 09:20 PM | #13 |
Rep 21
Hi. Newbe on the forum.
Just wanted to ask If one was going to use a 245/35-20 for front, how about load index... a 245 tyre dosen’t have a load index high enough for my 535d xdrive, ( which is supposed to have 96 If I recall correctly )🤷🏼*♂️ What’s your take on this |
09-18-2019, 02:09 PM | #14 |
Rep 5,140
09-18-2019, 02:10 PM | #15 |
Rep 5,140
245/35-20 is the OEM 20" tire size for F10, i.e. no issues.
09-20-2019, 12:57 PM | #16 |
Rep 2,588
09-20-2019, 03:18 PM | #18 |
Rep 2,588
09-20-2019, 03:28 PM | #19 |
Rep 374
Changing overall diameter of all wheels should cause no problem other than a slight speedo error. I did this on my X3 when changing all four tires from 245/50-18 to 235/55-18. The diameter of the latter is slightly greater, but the vehicle was not negatively affected by the small difference.
09-20-2019, 07:55 PM | #20 |
Rep 697
Drives: 2013 535xi
I ran 245/50/18 winter tires on my F10 for four seasons with no issues.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
