12-17-2015, 12:35 AM | #1 |
Dream crusher
984
Rep 2,421
I'll make this short and to the point. Get Fast Bit DV+ is an excellent compliment to any tune. I understand it's not a power mod it just holds the power better. This is especially true since I own a 6MT and average times between shifts can be as long as a second when I'm not hustling the car around. I no longer have to rebuild boost anywhere what I did before. The oem DV was not leaking, but the spring was definitely not holding boost as strong as GFB does. Because I hold on to so much boost, when it does purge, it sounds like a more refined BOV. Not ricey at all. BTW, I've had my GSR tune for sometime now and have seen psi hit 20 so when it lets boost go it's a very audible swish sound, even on the freeway. Fun to pass cars with a swoosh as I shift gears
The pros: - faster off the line and 1-3 gears holds much stronger - whoosh sound got way cooler - near bullet proof plunger - GFB Spring and no errors or codes so far The cons: - installation cost - probably not going to remove it if I sell the car due to cost - doesn't hold boost as much I was hoping It changes where and how the power is delivered, but not in a bad way. Changes the characteristics of the vehicle, but you won't want to go back after you adjust. GFB warns of using their spring and that codes might be thrown. I thought don't make me use the ICarly bmw app every WOT. I've pushed my car pretty hard and so far no errors. If you can swing the cost and you've already tuned your car this is a great addition. If you own a tuned n55 6 MT it's a must. Big ups to GFB, great product!
IG: @bmwdoubles |
12-17-2015, 12:42 AM | #2 |
Rep 14,522
interesting Bro! you have a link?
12-17-2015, 12:46 AM | #3 | |
Dream crusher
984
Rep 2,421
You could get it directly from GFB, but I've had good experiences with ECS tuning.
IG: @bmwdoubles |
12-17-2015, 12:57 AM | #4 |
Rep 14,522
nice! thanks! i'll check it out!
12-23-2015, 10:44 AM | #5 |
Rep 172
How much did it cost to install?
09 335xi AT, Pure Stage 2 'DD' turbos, JB4 G5 ISO w/anti-lag, MHD Trebila tune, Fuel-It Stage 2 LPFP, NGK 1 step colder plugs, BMS meth kit w/dual cm7, BMS DCI, VTT inlets/outlet, RB PCV valve, BMS OCC, N20 tmap, Cyba Scoops, Lux H8 160, VRSF 7" FMIC, VRSF DP, Custom exhaust, VRSF Chargepipe, GFB SV50 BOV, ER Sport Series Oil Cooler, UUC front sway, M3 rear sway w/powerflex bushings, BC Racing coilovers, xHP Stage 3, Hawk HPS 5.0 brakes
12-23-2015, 07:18 PM | #6 |
Rep 91
Nice write up, used these on my GT-R and loved them. I ran them full vent, amazing sounding BOVs.
2007 M5, 6 speed, Silver Gray Metallic, Full Black Merino Leather, Brushed Ti Trim, HUD, Active M Comfort Seats/Heated & Cooled, Navi, Premium Sound, HK L7, Active Steering/Suspension, PDC, Rear & Side Sunshades, Adaptive Bi-Xenon, Voice Command, Custom S/W, Passport 9500ci w/jammers, Dinan High Flow Air Mass Meter/Intakes, CF Front Strut Brace, S1 Suspension & Free Flow Exhaust, Evolve S2 Tune
12-24-2015, 10:43 AM | #7 |
Rep 354
Drives: 2017 F80 ZCP MW/SO
what was install cost and hours in labor?
Current: 2017 F80 ZCP MW/SO @EnzoRacing PTF BM3 STG 2 GTHaus Meisterschaft GT2 Exhaust SSR Intakes
Swift Springs @drivingwithbenny |
12-24-2015, 12:54 PM | #8 |
Rep 14,522
Any audio clips?
12-24-2015, 06:49 PM | #9 |
Dream crusher
984
Rep 2,421
Labor time was 5 hours. I have a good bmw mechanic so can't really and openly disclose the price, but you do the math.
IG: @bmwdoubles |
12-25-2015, 09:34 PM | #10 | |
Rep 354
AUDIO CLIPS PLEASE!! WOOOOSSHHHHHH!!
12-25-2015, 11:35 PM | #11 |
Dream crusher
984
Rep 2,421
I had to get under there for other reasons I won't disclose, so my 5 hours was merged into another purpose. So yeah, if you wanted to install the DV+ plan on draining the radiator fluid and removing the power steering assembly. Ok ok ok sound clip incoming
IG: @bmwdoubles |
01-03-2016, 02:41 PM | #12 |
Dream crusher
984
Rep 2,421
All in second gear gas, let go, gas, let go, etc. kind of hard to capture
http://sendvid.com/l4uxbus4 Look out for that dead skunk!
IG: @bmwdoubles |
