2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Condensation / Water Leak Rear Footwell
      01-17-2017, 06:49 AM   #1
Taheemr
Drives: M6 GC
Has anyone had water ingress in the rear passenger footwell (right hand drive cars) I noticed the other day that the carpet is saturated, no obvious signs of leaks, the cars only 4 yrs old. I know there are some drain holes under the footwell, which i have tested by pouring water into the bulkhead and it seems ti drain out fine, any others had this issue, what was the fix
      01-17-2017, 10:05 AM   #2
Kaane
Drives: 2013 550i
Check Sunroof drains. If they are clogged water will run down the sides and all over the car.
      01-18-2017, 05:33 AM   #3
Taheemr
Drives: M6 GC
i have no sunroof
      01-24-2017, 06:45 PM   #4
DaHeadlightGuy
Drives: 2013 DSB F10
Might be the vapor barrier failing in the door. pop off door panels on that side and see if the vapor barrier is torn or the adhesive has failed.
