2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Mission Performance stage 2 F10 N55 flash updates
      07-16-2016, 08:31 PM   #1
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Thanks to Alex at MissionPerformance we were finally able to sync our schedules and head over to the dyno. Shots out to ocN55 and apexlocator for being their amazing rides to the party! As we know the F10 N55 is the same amazing block as other chassis, but not in terms of tuning abilities. BMW for some reason decided to give the 535 no love in regards to the ecu and the turbo. During my time with Alex he has discovered several limitations in regards to maf sensors limits, ecu rpm management limits or lack there of and more recently the turbo is not the same as its smaller brother 3 and 435's.
Alex has championed these limitations by reprogramming the ecu to have similar torque management and maf CFM upper limits like its smaller sibling along with a string of other parameters including waste gate settings. This reengineering of the F10 535 ecu has resulted in some impressive results for a stage 1 at 320/420 that is reliable and safe.
Now onto the updates of the stage 2 results. Today Alex has found a way to hold power by way of wastegate control and some other parameters not disclosed here to hold power across the range. On the Dyno chart below you'll see he was able to to produce 344/505! Keep in mind the tune is made for 91, but I was running a DP and 4 gallons of e85. You can see in the Dyno chart that the clutch is slipping. I'm going to be upgrading the clutch to a 550 that can easily hold that and it's OEM. I'm pretty sure Alex would not recommend this on ATs. That said I believe ATs can comfortably hold 450tq and the stock 535 MT clutch can hold 420tq. This is still a work in progress and I will continue to up this page as we move forward. Next move is upgraded map sensors and 550 clutch. Shortly following that is a bigger propeller possibly 62 and relocating the intake.
IG: @bmwdoubles
      07-16-2016, 08:43 PM   #2
vivanapoli806
Drives: 2012 535i Xdrive Msport
Well my mind is officially made up and I'm going with a MissionPerformance tune. I was debating other tunes for my Xdrive but am pretty set on this. I just hope the auto xdrives can hold the 344/450 or pretty close to it. Thanks for all the updates throughout the entire process.
      07-16-2016, 08:44 PM   #3
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
Man I'm on this like white on rice.
As soon as my new wheels come and and get on the car I'm going to mail him my DME.
I don't think the stock LS2's would like this very much lol
      07-16-2016, 09:37 PM   #4
Secret_Asian
Drives: f10 lci luxury line
Do you mean 62mm exducer? Isnt that the stock size?
or are you referring to the inducer wheel being 62mm I think thats a bit bigger than a pure stage 2
or are you talking about the compressor wheel or turbine wheel or both??
      07-16-2016, 10:08 PM   #5
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Compressor wheel
IG: @bmwdoubles
      07-16-2016, 10:51 PM   #6
Secret_Asian
compressor wheel exducer is 62mm stock i think no? Stage 1 is 67mm stage 2 is mid 70s
      07-16-2016, 11:05 PM   #7
AWF87M2
AWF87M2's Avatar
827
Wow those are some insane numbers! Whats your current IAT? On my current stage one tune with some normal driving around town in mid 80's weather, I am getting around 135-140 F.
      07-17-2016, 11:10 AM   #8
Infamouscrew02
Infamouscrew02's Avatar
75
Drives: 13 535 M-Sport
So, I wonder if there would be any benefits of swapping our turbo for the turbo out of a 335 or a 435? Or if just going straight to the Stage 1 Pure turbo is the better way to go.
      07-17-2016, 11:22 AM   #9
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
There are substantial benefits for a turbo swap from a3 or 435 that will put you up closer to 400hp.
IG: @bmwdoubles
      07-17-2016, 12:17 PM   #10
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Yes you were correct stock turbine is somewhere around 60 so MP is thinking it's going to be 65-68 depending on available material. Also the compressor wheel will be enlarged and lightened.
IG: @bmwdoubles
      07-17-2016, 12:58 PM   #11
B58BULLY
B58BULLY's Avatar
Drives: sunset orange metallic f30 340
God i hope i hear back from them soon on the ny group buy those would be some sick numbers to have on xdrive plus with mboot he can update me no problem i would love 350/450 on awd ????
Is that a customer intake i see that piping routed towards the front
18? 340 XDRIVE
#BM3TUNING
      07-17-2016, 02:00 PM   #12
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
elg0rd0yadigg 350/450 is going to be a stage 2 with DP and 93 or e85 blend.
What do you mean by customer intake?
IG: @bmwdoubles
      07-17-2016, 03:17 PM   #13
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
should get an activehybrid 5 on this. N55 engine with the gearbox off the 535D so can handle 750nm !!
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      07-17-2016, 03:23 PM   #14
AWF87M2
AWF87M2's Avatar
827
Are you referring to the black plastic piping that goes to the bottom? If so those are the stock intake pipe for the F10 535i.
      07-17-2016, 04:32 PM   #15
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Ah custom intake... It's stock. We're working on a custom one that comes from the passenger side directly to the inlet.
IG: @bmwdoubles
      07-17-2016, 05:31 PM   #16
AWF87M2
AWF87M2's Avatar
827
Yeah. Alex told me about it last time I was there. So it is basically a one piece design as opposed to the stock where it is separated by the small tube for the MAF sensor? BTW are you still running stock Chargepipe or aftermarket with your current power figures?
      07-17-2016, 05:37 PM   #17
vivanapoli806
@Bmw doubles I would def be interested in an intake for our cars. Hopefully they come through on this. Do you know if they plan on doing a stage 1+ tune like Cobb had for just an upgraded fmic if we want to keep our stock dps?
      07-17-2016, 06:15 PM   #18
B58BULLY
B58BULLY's Avatar
LOL yeah sorry on the typo tried to edit on app but kept failing...
18? 340 XDRIVE
#BM3TUNING
      07-17-2016, 06:15 PM   #19
Secret_Asian
let me know happens with that, sounds basically like a pure stage 1 at that point from the way i read the thread
      07-17-2016, 06:31 PM   #20
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I still have time to think about this so when my car goes into storage over the winter I can send the ECU out but...but seeing that I have to remove the intake manifold or what not has got me discouraged
      07-17-2016, 07:33 PM   #21
AWF87M2
AWF87M2's Avatar
827
It is really not that hard, just a bit of pita to remember all the steps and what goes where,fyi there are a few diy guides online for the F10. If you can't do it yourself you could always hire one of those mechanics from yourmechanic.com to do it for you.
      07-22-2016, 05:02 PM   #22
exia_m3
exia_m3's Avatar
181
Drives: 2017 F80 ZCP MW/SO
2013 BMW E92 M3  [0.00]
2017 F80 M3  [0.00]
Come To Ny T_t I Need Thissssss!!!
Current: 2017 F80 ZCP MW/SO @EnzoRacing PTF BM3 STG 2 GTHaus Meisterschaft GT2 Exhaust SSR Intakes
Swift Springs
@drivingwithbenny
