2010 2011 BMW 5 Series Forum F10 2013 Headlight LED Upgrade "Lighting Package" |
10-23-2016, 02:40 PM | #23 | |
Rep 98
Drives: F10 535i M Sport - e31 850csi
Because I plan to buy a pair of those and the shippment + additional VAT for UE import are very expensive (200$ for the shippment toward Germany and 300$ of additional VAT for the import) So if it will does not work on my 2012 535i I will kill myself Another question, where can you buy replacement bulb for LED ? I didn't see any LED bulb replacement on the net (for this aftermarket Umnitza and for the OEM LED headlight) |
10-23-2016, 03:42 PM | #24 | |
Rep 120
2013 BMW M5 - B&O Sound - Piano Black trim - 2 toned grey/black interior.
2016 M3 - Fully Loaded - GF's car Grave Yard - 2014 BMW 640i - 2007 BMW 335i - 2006 BMW M5 - 2003 Infinti G35 - 2002 BMW 740i - 2002 CBR 954r - 2000 BMW 540i - 2000 BMW 328i |
10-23-2016, 08:29 PM | #25 |
Rep 997
10-23-2016, 10:04 PM | #26 |
Rep 120
I took some shots and it's a bit hard to tell BUT believe me when I say my lights are way brighter than the LED M3 lights.
lowered the brightness (phone pic)
10-24-2016, 11:29 AM | #28 |
Rep 120
low beam - although they need to be aimed down a bit
10-24-2016, 11:36 AM | #29 |
Rep 98
another question, the coding is needed just to remove the fault code but even without removing the fault codes the headlights work fine ?
For the coding, the guy who did it, he used E-Sys ? |
10-24-2016, 01:36 PM | #30 |
Rep 120
Yes, lights work fine without coding - coding is to remove the annoying beeping but they worked fine on my 1 hour drive to the coder. I'm not exactly sure what the system is called but it's the same system (from the looks of it) that all of my other BMW's were coded with.
10-24-2016, 05:22 PM | #32 | |
Rep 878
These headlights look great, definitely need to re-aim though
-WJV
10-24-2016, 09:47 PM | #33 | |
Rep 465
2013 F10 535i M-Sport Alpine White Oyster/Black OEM M5 Exhaust with Resonator Delete |
10-25-2016, 12:42 AM | #34 |
Rep 98
I sent an email to Umnitza to know if the LED bulbs can be bought on every specialized automotive car store but they didn't reply me...
If you can't find any part replacement for these headlights I will not go for them... imagine you have a problem with a part (the ballast which controls the LED or the bulb itself) how do you deal with it ? You have to change the whole headlight ? |
10-25-2016, 02:40 PM | #35 |
Rep 194
I actually turn the outer ring by hand but as you can see, it actually is two different sized allen key adjustable knobs. The smaller one in the very middle supposedly adjusts either width, or left/right of the beam (I can't tell). The larger one is the one that adjusts my lights up/down.
10-25-2016, 04:36 PM | #36 |
Rep 1,587
I had Umnitza headlights on my E46 8 years ago. While I wouldn't personally recommend them to anyone as one side stopped working within a year (not the bulb, some other piece within the headlight), this could be a much better product.
10-25-2016, 04:40 PM | #37 | |
Rep 98
Even now, I don't see any bulb replacement for the LED headlights... I looked for LED bulbs replacement on realoem.com and on the ETK and I didn't find any reference for the LED bulb, they are even not represented on diagrams. It's strange... |
10-26-2016, 03:47 AM | #38 |
Rep 98
I didn't receive any reply from Umnitzä to my question ...
I sent email to chinese sellers on aliexpress which sell the 'same' LED headlight for F10. They replied instantly to my questions, and... they said me there is not replacement part for the LED bulb.... in case of failure, I have to send the headlight to them to open them and replace the integrated LED bulb... For me it's not a good solution. I think it's the same thing with these Umnitza headlights, that's whu they didn't reply to my ask... |
10-26-2016, 07:40 AM | #39 | |
Rep 997
I don't know if any modern LED headlights have easy replaceable bulbs. Remember modern LED headlights don't have LED bulbs, they have clusters of LEDs soldered together on the circuit board. So if an LED in your OEM LED headlight goes bad they will have to replace the entire headlight. Keep in mind that most LEDs are extremely reliable if powered correctly and should outlast the lifespan of your car.
10-26-2016, 07:51 AM | #40 |
Rep 98
10-26-2016, 08:02 AM | #41 |
Rep 997
10-26-2016, 08:20 AM | #42 | |
Rep 98
ok, I hope |
10-26-2016, 08:29 AM | #43 |
Rep 997
10-27-2016, 02:04 PM | #44 |
Rep 2,070
I would trust/expect an OEM LED unit to last a very long time and have very low failure rates.
But we all know that poor quality LEDs can fail very quickly. So the question is, what sort of quality are Umnitza products usually? |
