2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Engine noise 535i
      08-15-2023, 08:30 PM   #1
xmann
Drives: 535i 2012
Engine noise 535i
Squeaky noise from the engine is still present even after the belt tensioner assembly kit was replaced. Any Idea what could be causing this? This noise is even longer when the car is in motion. Any idea what could be causing this?
This is 2012 535i with 123k miles. This noise happens right before a misfire at idle. I recently replaced the oil to liquid moly 5w40. There is no check engine light. The indy that replaced the tensioner thought that was the cause of the noise and wanted to replace the valve cover as the solution to the misfire. That did not add up for me. Any one seen something similar before? maybe turbo diverter valve gone bad?
https://youtube.com/shorts/k4YuUMHrLw8?feature=share
https://youtube.com/shorts/dCjUw4L-Ilk?feature=share
      08-15-2023, 10:35 PM   #2
M_Bimmer
M_Bimmer's Avatar
583
Drives: G12 B7, G07 XB7, F02 B7, 991.1
Does the noise go away when you remove your oil filler cap? If so, it's the valve cover.
