2010 2011 BMW 5 Series Forum F10 Guys On The Forum With BMS For 550i |
12-27-2013, 10:32 PM | #23 |
Rep 2,080
To be clear here... A 2011-2013 550 on bms stage 1 will make the same or more power than a stock 2014+. A 2014 bms stage 1 will make more power than a 2011-2013 bms stage 1, most likely. And finally a stage 2 2011-2013 will make considerably more power than a stage 1 2014+... Likely at least 30hp and 30trq to the wheels more.
Once someone dynos a stock and stage 1 2014+ on a dynojet, I'll do the same once I get bms stage 2. I'll even do it the same day if someone is local to the tri-state area for no other reason than sharing with the greater forum at large. |
12-27-2013, 11:04 PM | #24 | |
Rep 2,416
2011 550i RWD 60-130 7.35
12-28-2013, 12:14 AM | #25 | |
Rep 1,250
Drives: 20' X3M CP
Totally different set up then the N63 stage 1 set up. Car feels totally different. Vs before. I mean considerably. |
12-28-2013, 12:24 AM | #26 |
Rep 2,416
now you need to go to 1/4 track and beat my stage 1 1/4 record =D
12-28-2013, 12:37 AM | #27 | |
Rep 1,250
Drives: 20' X3M CP
A 13 with stage 2 and 14 with stage 1 should be very close. I'm dynoing with Terry next week hopefully and we shall see. Like I said before. The 13 isn't 400 crank. Terrys 13 put 392 stock at the wheels. So BMW severely undrated it. The only way you are correct is if the 14 was rated correctly or over rated . Because with a 20% drive train loss. The 14 stock should be around 356 rwhp. Like I'm not arguing with you guys I'm just speaking numbers here. The 13 lost 8hp total from what BMWs 400hp rated motor. So if the 14 is similar... 445-10hp is 435. Stock wheel hp. So with stage one added should be even more 465+ wheels. Again I'm going off of the 13s gains and factory drive train loss of around 10. Who knows maybe the 13 is the beast due to their claim or 400hp being totally false. Hope this makes sense Marc |
12-28-2013, 12:39 AM | #28 |
Rep 1,250
Drives: 20' X3M CP
12-28-2013, 01:10 AM | #29 | ||
Rep 2,080
12-28-2013, 02:21 AM | #30 | |
Rep 1,250
Drives: 20' X3M CP
Which means it wasn't safe and isn't something that he is going to put out 2nd to last run was the true stage 2 that he is running currently on his car. Which was 448 //517 Again no one is fighting you hear. I'm just going off of the numbers and what Terry told me. My car also has catless downpipes so the dyno were gna run will be higher then it should be. |
12-28-2013, 01:07 PM | #31 |
Rep 2,416
paddle shifters
12-28-2013, 09:27 PM | #32 |
Rep 1,250
Drives: 20' X3M CP
12-30-2013, 10:46 AM | #33 | ||
Rep 2,080
And the last aggressive run was pulling timing but will likely be perfect for 93 octane + 100 octane or octane booster mix. Terry was running 91 + octane booster which is a ways off. Again, well see one someone runs the updated n63tu stage 1 without Catless. Point here is, the new engine changes are clearly superior, bringing it in line with more with the m5 engine setup, so it should and will make more power. However, I think a stage 1 n63 will beat a stock n63tu and a stage 2 n63 will beat a stage 1 only n63tu. Plus, I think you're rwd, right? So your track times won't be in line w/ the awd anyhow. A good measure will be 60-130mph as per standards. |
12-30-2013, 11:32 AM | #34 |
Rep 8,809
If Terry sends his revised TU S1 tune to me I can meet up with Scott and BB to do some 'testing' since my car doesn't have downpipes. I would be interested in doing some dyno runs together so we have an apples to apples comparison. Same day, same dyno, same gas, same mods etc...
BB needs to be running 93 with standard bms boost to really show how the motors compare. Not his plus 4psi and race gas combo he likes to run dominating every race lol Alan
12-31-2013, 10:01 AM | #35 |
6'0 / 250lb
137
Rep 1,797
We need to get some STOCK dyno runs of the 2014. Does anyone have any?
BMW may have realized how under-rated the 2013's were so MAYBE their new claim of 445 is more marketing than actual changes....?? Who knows what the differences between the M5's drivetrain and the 550's? |
12-31-2013, 10:51 AM | #36 |
Rep 8,809
Its more than just marketing with the new updated motor. There was a document floating around talking about exactly what changed in the 445hp motor mechanically and its pretty significant. BMS also said that the car also made more boost stock vs the old motor.
Alan
12-31-2013, 12:33 PM | #37 | |
Rep 2,080
The n63tu has different turbos I think as well, slightly revised in addition to variable vale timing and running more boost. Apples to apples no doubt the tu is superior. Excited to see net result since Terry thinks a S1 Tu will match a s2 regular n63. That would make a tu stage 2 have more power than stock m5's :-) with tune only. Add downpipes and race gas and wow. |
12-31-2013, 12:37 PM | #38 | |
Rep 1,250
Drives: 20' X3M CP
That's been my argument. If the 2014 is rated correctly then there should be no change vs a 2013 |
12-31-2013, 12:43 PM | #39 | |
Rep 1,250
Drives: 20' X3M CP
Terry and I are going on Thursday. So we'll see. I'm hoping they under rated it like they did the n63. If so should be making some power. Right now my car does loose traction in 2nd gear at 30mph so I'm sure it's putting down some power. I'll keep I all posted. |
12-31-2013, 02:45 PM | #40 | |
Rep 2,080
------------ Stock M6 on 91 octane - 503 rwhp, 488 rwtrq : http://www.bimmerpost.com/tag/f10-m5-dyno-figures/ Also, my buddy with a S1 2011 N63 550i RWD spins the tires in 2nd. All that torque and no LSD :-/ I just bought a 1987 325is with 66k original miles... damn car has a LSD but new non-M's don't, it's messed up. All RWD BMW's should.... Can you post of a video of a 60-130 run, or just a speedo shot accelerating? Nothing scientific, just curious. |
12-31-2013, 06:22 PM | #41 |
Rep 1,250
Drives: 20' X3M CP
I have one with out stage one.
Stock with er downpipes right after install. Litterly coming off freeway on my way back from picking it up. It felt much faster few days after ecu fully adjusted. Video is sports+ with stock tranny settings not in sports auto. As you can see. Just in D. Last edited by combatbmw; 12-31-2013 at 06:39 PM.. |
01-07-2014, 11:43 AM | #44 |
Rep 1,250
Drives: 20' X3M CP
Ok let me know, ill post the speedo of my r1 after
Beeee ATCH
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
