2010 2011 BMW 5 Series Forum F10 n63 valve seals and oil consumption |
07-23-2016, 03:17 PM | #1 |
Rep 41
so I had my valve seals replaced and intake ports cleaned but the car is still burning around a liter every 3000KM. what else would be causing the oil consumption and whats the fix?
07-23-2016, 07:49 PM | #2 | |
Rep 736
07-23-2016, 11:29 PM | #4 |
Rep 41
Black550FL0.00 |
07-23-2016, 11:32 PM | #5 | |
Rep 41
make sure its actually the valve seals that's the problem.... ie smoke from tailpipe when car is idle and you tap the gas. mine didn't have that symptom I didn't notice any difference, except no more vibrations cruising at low rpms. that has definitely improved. I assume that's because of the intake ports being cleaned not the valve seals themselves. I still get tons of soot on the exhaust pipe and burn about the same oil as before, maybe slightly less |
07-23-2016, 11:34 PM | #6 | ||
Rep 736
07-26-2016, 10:20 PM | #7 |
Rep 163
Could very easily be turbos seals. Check for axial/radial shaft play on the turbo shafts.
08-27-2016, 04:01 PM | #9 |
GooseInOz
11
Rep 44
Yesterday the dealer diagnosed my problem (burning oil, 2 liters over 10,000 miles) as an issue with the valve seals leaking.
They estimated it would cost $6,600 to repair. Yes, $6,600. When I balked -- because it's a $75,000 car with 80,000 miles -- they offered to discount it by 25% or just under $5k. Painful. Probably not a coincidence that my sales guy just happened by in the middle of this to see if I wanted to look at the new 7s. Big sigh.
Current: 2017 Porsche Macan S, 1991 VW GTI 16v, 2012 550xi with M-package, 2009 Porsche 911 Carrera S, 2006 Range Rover Supercharged
Past: 2007 550i, 2007 335i coupe, 2002 Ford Explorer, 1994 Acura Integra, 1985 VW GTI 8v, 1984 Chevrolet Malibu Classic |
08-28-2016, 04:18 PM | #10 | |
Rep 785
Since ownership, I've been topping off 1 liter every oil change. |
08-29-2016, 05:23 PM | #12 |
Rep 113
bmw now has a toolkit that allows them to do the job without engine removal which is supposed to reduce the price(or for many dealers just boost profit)
