02-11-2012, 03:23 PM | #1 |
Rep 15
Big Leak!
When I opened the back driver side door this morning (to put my coat on the backseat before setting off) I noticed a gush of water falling out from under the door (the amount I guess was about a cup full). I then noticed a small pool of water in the centre of the rubber floor mat. On futher investigation I discovered the entire footwell is completely saturated.
It did rain heavy last night but that shouldn't be a problem. This is just one of many issues I have had with this car over the past 2 years. I really miss my 2007 E60 - it was streets ahead of this car. Luckily my warranty is still valid for another month but this car is proving to be a right pain in the ass. |
02-11-2012, 10:00 PM | #3 |
Rep 363
Wow... That's terrible.. What did your dealer/ service tell you?
2012 535xi Imperial Blue Oyster interior
2012 Lexus CT200h Star fire pearl Ivory interior 2008 Infiniti G35x Aspen pearl Graphite interior - you are missed my friend |
02-12-2012, 04:18 AM | #5 |
Rep 15
The dealer said that they will have to do a detailed examination to establish if the fault was caused by something other than faulty design, workmanship or materials. They will need the car for a number of days as detecting leaks can be very difficult.
They also said that the car has to be inspected before the expiry of the warranty otherwise the problem will be mine. By what I witnessed I'd say it shouldn't be too hard to detect. |
02-16-2012, 01:27 PM | #7 |
Rep 10,185
Interesting. Each car is put through a very through leak test in a water chamber before leaving the factory.
Did you have any work done on the car since you got it ? Any notable damaged door seals ?
BMW if you are reading, I need a job, Please. |
02-17-2012, 07:32 AM | #8 | |
Rep 519
Picture it this way. Two "U" shaped plastic assemblies (What you see when you open the sunroof) one faces forward and is located at the rear of the car, the other faces rearward and is located at the front of the car. Where the tips meet and interlock is where my leak was taking place. The corners of the two "U" assemblies are where the drain tubes are located. Hope this helps and sorry again for the poor explanation. |
