2010 2011 BMW 5 Series Forum F10 How to replace indicator glass strip |
04-25-2016, 12:31 PM | #1 |
Rep 222
Have a 65 plate F10 M Sport and found a chip on the outer right wing strip (part number 8 on this image http://www.etk.cc/bmw/EN/search/sele...38/63137308536).
1. Any online UK site recommended to purchase this part? 2. If i replace it myself are there any instructions on how to take the wing mirror apart? Cheers |
09-05-2017, 09:53 AM | #2 |
Rep 1
Did you manage to replace this and if so were there any issues? I have ordered a replacement light strip but wondered if there were any problems wiring it in. It looks like the wires are connected back inside the vehicle. Is it necessary to remove the wing mirror assembly?
09-05-2017, 11:35 AM | #3 |
Rep 293
I replaced mine last year. I bought a genuine replacement from my local dealership - it wasn't too expensive. I had trouble with mine as it was damaged by a passing car which broke some internal parts of the wing mirror. The plastic cowling above the light strip just clips off - you have to be brave and force it off. I had some plastic trim removal tool to start it off. A few screws internally and that's it. The wiring runs into the car where the triangular plastic cover is if you don't have speakers. Just force that off and gently remove and packing that in there and then pull the cable up to show the plug. Securely hold the end and disconnect. Be careful not to drop the cable back into the door card or you will have to take that off. Fit the new one and feed the cable through - reconnect and put everything back together.
JLR19691882.00 |
