2010 2011 BMW 5 Series Forum F10 Water seeps into headlight |
02-14-2011, 05:37 AM | #1 |
Rep 144
Hi
This happened to me a while ago.. but I still would like to know if it happened to anyone else. First week after buying my car I noticed some dry spots on the inside of my right headlight. Couldn't clean it, but still didn't worry too much about it. After one rainy day i noticed some water on the inside of my right headlight. The next day I noticed the headlight cover was foggy from the inside. Then, a few days later the right headlight stopped working (probably burned out). The dealer will fix it. But the question is: has anyone else faced a similar issue? Thanks |
02-14-2011, 04:49 PM | #4 |
Rep 231
BMW started putting this in the manual now, some condensation is apparently normal. It should go away but if it doesn't and lights not working, then dealer should replace it for free.
02-14-2011, 11:23 PM | #5 |
Rep 144
Thanks all...
A few years ago, one of my friends bought a new car (not BMW) from a local dealer. He noticed after a while that the paint was coming off at the tip of his right fender where it meets the headlight. He took it to a random workshop to get quick feedback. The workshop said that the car was involved in an accident and that the fender was repaired. They took off the headlight and saw how the fender looked from the inside. The repair job was clearly a very poor one. He took the car back to the dealer and made a very big deal about it. The dealer tried to deny it at first, but then said that some cars get some minor bumps during devilery by sea, and when they arrive they're inspected and given the necessary touch-ups if needed. After that the story got ugly and dragged everyone from the manufacturer to the shipping co. to the Insurance co. Anyway, when i saw the water in my headlight the first thing that came to mind was this story. But now that i see it's more common, i'm less worried. |
02-15-2011, 01:19 PM | #6 | |
Rep 59
There should be a really tight seal no water should be able to get inside...replace under warranty before it breaks. Xenon lights is quite expensive. |
02-15-2011, 11:55 PM | #7 | ||
Rep 298
I have had xenon lights in my last 4 bmws (inc f11) and all units have contained a vent port on the back to allow for condensation/air expansion I think BMW also mention in all owners manuals some condensation is normal. I would say if the condensation is excessive and very frequently reforms with being "burnt" away almost instantly when lights are on then I would get it checked. One unit on my e60 was like this and dealer did replace it as it wasn't in what they called normal tolerances. |
02-16-2011, 12:58 AM | #8 | |
Rep 231
02-17-2011, 05:09 PM | #10 |
Rep 144
Well, Dealer said that some foggyness and condensation is normal and will go away because of the built-in vents.
But he also said there should be no stains on the inside of the cover. He saw my car and decided right away that the headlight was faulty (probably bad seal). He will change the whole right headlight unit under warrenty.... no questions asked. it's now on order... Thanks |
02-11-2014, 06:57 PM | #11 |
Rep 203
I just had mine changed by BMW under warranty (expires in two weeks) as there was a small condensation issue. Whilst the condensation came and went, and the technician said he did not see anything wrong with them, there was an ever so slight moss like substance making an appearance so they went ahead and changed them anyway. I cannot fault them, they were very helpful.
02-13-2014, 12:07 AM | #13 |
Rep 425
My 2 cents:
Had the same issue, water got in to the headlight, went to dealer and now I'm out $825 cause just ran out of the warranty and extended does not cover headlights. FML
02-13-2014, 10:04 AM | #14 |
Rep 203
Indeed. this is why I changed them before the original warranty expires at the end of the month...
