2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Steering Wheel Up Grade - Value Option
      02-12-2018, 07:45 AM   #1
JLR1969
Drives: Kubota GR1600
I am constantly looking to improve the car but keep it as OEM as possible.
The latest modification was the steering wheel.
Replaced the lower parts with the M5 pieces and replaced the paddles to the M versions.
The two plastic parts are BMW Original and the paddles came from China although I swapped the control modules from the old paddles to make sure all of the electronics were original.
Total cost £244
Hope you like it.........
      02-13-2018, 11:01 AM   #2
shiner
Drives: 535D MSport Touring
Looks great. I am thinkign of gettign mine modded too but goign Royal Steering Wheels.
2015 F11 535D M Sport Touring, Space Grey, VDC, HUD, Comfort Seats, Sport Auto, Pro Media. GONE
2013 Z4 35is + tons of options. CURRENT
      02-13-2018, 11:41 AM   #3
JLR1969
Alcantara?
      02-13-2018, 11:49 AM   #4
shiner
YEs, maybe.
      02-14-2018, 03:29 AM   #5
Mogwai888
Mogwai888's Avatar
64
Drives: iX3
Very nice upgrade.
Liking the paddles.
Was it a wheel off job or can you install with the wheel in situ?
      02-14-2018, 04:19 AM   #6
JLR1969
Originally Posted by Mogwai888 View Post
Very nice upgrade.
Liking the paddles.
No the wheel has to come off and airbag removed.
      02-17-2018, 08:22 AM   #7
shiner
How did you do that please?
      02-17-2018, 05:33 PM   #8
JLR1969
Open the boot and lift the boot floor flap
Unscrew the two bolts that hold it in place and remove the boot floor carpet piece
Undo the negative on the battery and wrap it in a cloth to stop it shorting
Leave the boot open do not close it or you won't get back in!!!
On the steering wheel sides under the wheel there is a hole on each side, push a flat blade screwdriver in the hole and you will feel a metal wire, push it inwards and pull the airbag gently upwards.
Do this on both sides and the airbag will be free.
Carefully undo the electrical connector that's at the 12'o clock position behind the airbag and then it's free
Place the airbag upwards on the floor mat
That's it, airbag removed.
      02-20-2018, 04:52 AM   #9
shiner
Thanks.
When you reconnect the negative do all the car systems come back again as they were or do you lose codes, settigns etc?
      02-20-2018, 05:28 AM   #10
JLR1969
Thanks.
All back as normal
